Raspberry Pi Forum Your Breakdown of Raspberry Pi Customization
  • Replies 68 replies
  • Subscribers 720 subscribers
  • Views 8193 views
  • customized pi
  • customized_pi
  • customization_service
  • customization
  • customisation
  • customization service
  • raspberry pi
  • raspberry-pi
  • raspberrypi
  • customised pi
  • customisation service
spannerspencer
spannerspencer over 10 years ago
You might have just seen the official joint announcement from the Raspberry Pi Foundation and element14 regarding an exclusive new customization service for the Raspberry Pi, and we'd love to hear your thoughts on the subject.
Bulk Customization Services
The facts are these:
You can now open a dialogue with element14 about creating a Raspberry Pi that's tailored to specific needs, on orders of 3,000 units or more. You can reconfigure the board, add new functionality, add or remove features, change the memory configuration; pretty much anything besides tinkering with the GPU and related software. A full breakdown of the service can be found here: Raspberry Pi Customization Service
Cooking Up a Custom Raspberry Pi
Clearly this is aimed squarely at OEM manufacturers, suppliers and bigger companies due to the minimum order quantity, but such places are still populated by engineers and makers who'd be the ones that determine just what a customized Raspberry Pi would require for specific needs.image
So we thought it'd be valuable to get the element14 community's opinion on this new service.
Will companies find a lot of use for it, and what might they need a custom Pi for?
Which kinds of customization are likely to be the most popular? Expansion of the device, or minimization?
Give us your predictions on the future of element14's Raspberry Pi Customization Service below, and who knows how it might evolve.
  • spannerspencer
    spannerspencer over 10 years ago in reply to e14 Contributor
    Hey, that's an interesting notion though, Enrico. What if someone started a Kickstarter campaign to have a batch of 3,000+ customised RPis put together (using the crowd's bulk buying power), and then effectively making them available to users in much smaller (even single) quantities. It'd be no small task, as you point out, but it's an intriguing thought, eh?
    e14 Contributor over 10 years ago in reply to spannerspencer
    The trick being to find the modification to the Pi that will gather enough buyers for 3000 Pi's of a brand new design. I'm not sure if it will sell when everyone wants something slightly different.
    Lets imagine two Modded Pi's:
    Super Pi: As normal Pi + Arduino, RTC, DAC, Relays.
    DAC output at 0-10v, Arduino analog inputs able to accept 0-10v or 4-20mA at 10v, relay outputs safe for use at 240v 10A.
    Cost £100?
    Slim Pi: Normal Pi with reduced height by: Swapping double height USB sockets for single height, GPIO pin header not soldered on (user can then solder to individual through hole pins or add a header as they choose). True Powerdown facility added (so when you tell the Pi to turn off, it actually stops using power) with through hole power on/off pin headers so you can add an external switch.
    Cost: a little more than a normal Pi?
    Each of those cases would appeal to a market, but would that market be large enough to support 3000 purchases?
  • gadget.iom
    gadget.iom over 10 years ago in reply to e14 Contributor
    Cost £100?
    Exactly!
    You'd get "What about a DDR3 Socket", "What about SATA sockets", "Can it have a VGA and DVI sockets", "Where's the WiFi", "Bluetooth?", "NFC", etc etc.
    e14 Contributor over 10 years ago in reply to gadget.iom
    Precisely,
    Anyone doing a Kickstarter would have to find a market niche that the Pi variant will fill, a niche big enough to support 3000 sales whilst being adaptable enough to absorb the inevitable requests for slight variations and still be cheaper  than other existing products.
    I hope we see some of these come to life, but I wouldn't bet on it.
    Perhaps the Element 14 team will have lower prices for open designs than proprietary ones?
    This would make sense as a broad library of decent open designs will allow for cheap modifications in the future.
  • gadget.iom
    I imagine most of them will be private customisations for companies to integrate with their products.
  • rolandl
    rolandl over 10 years ago
    2 things that would improve our beloved Pi would be WiFi and getting rid of the sd-card.
  • SGarciaV
    SGarciaV over 10 years ago in reply to rolandl
    Why, regarding the SD card? What alternative do you see for the SD card?
    balearicdynamics over 10 years ago in reply to SGarciaV
    Internal flash memory, that is what the SD card replaces respect a normal Linux embedded device.
  • gadget.iom
    gadget.iom over 10 years ago in reply to rolandl
    I believe the SD card satisfied the education sector, where students could swap-out their work for shared classroom devices.
  • rolandl
    rolandl over 10 years ago in reply to gadget.iom
    It did. This thread however is about customization of the Pi and if I were to change it I'd get rid of the Sd card in favor of something that is soldered onto the PCB and it would include Wifi and removal of the ethernet connector for my application.
