Raspberry Pi Forum Script to change IP between Static DHCP
  • Subscribers 704 subscribers
  • Views 1515 views
  • python
  • static ip
  • script
ablock130
ablock130 over 9 years ago
Does anyone know of a prexisting script that I could use to swap IP address settings for the pi? I know I can edit the /etc/dhcpcd.conf file, but I would like to set up a little utility so I can have other people set up static IPs as necessary, without actually mucking around in the config file directly.
As a bit of background, we sometimes use Pis as data loggers in grocery stores. Because of security for their POS systems, all devices require static IP addresses, but often times the IT person for each store likes to do that commissioning themselves. I'd like to be able to send out a Pi with super simple instructions that won't open the door for potentially larger issues.
  • beacon_dave
    beacon_dave over 9 years ago
    how about:
    change to a static address:
    sudo ifconfig eth0 192.168.1.1 netmask 255.255.255.0 broadcast 192.168.1.255
    change to DHCP:
    sudo dhclient -r eth0 && sudo dhclient eth0
    or:
    sudo ifconfig eth0 0.0.0.0 && sudo dhclient eth0
