Raspberry Pi Forum DIY Electronic Drum Kits
  • Subscribers 705 subscribers
  • Views 1701 views
  • electronic
  • diy
  • drums
I would like to know if any one else has built a DIY Electronic Drum kit if so what type of drum triggers did you use?
Also how did you build your kit and what did you build it out of?
    dougw over 10 years ago
    I have used Piezo disks (benders). They are low cost but need to be isolated mechanically from each other because they are so sensitive they will respond to vibration coming from the next drum pad.
    You can see what they look like here:
    Tis The Season For Arduino
    To make a drum pad experiment with a layer of wood or plastic sandwiched between layers of rubber all sitting on top of the sensor.
    That's pretty cool, the build I have right now I used piezo elements and RCA jacks the module that I use is a Simmons SD7K,
    and I converted acoustic drums into an electronic kit for the heads I use DIY mesh drum heads I made myself with existing
    hoops and fiberglass solar window screen. To make the heads I cut the window screen to attach it to the hoops with hot
    glue then when the hot glue sets and dries I trim off the extra mesh. for the electronics I used angel brackets double sided
    tape the DIY drum triggers and craft foam. also small clamps are needed when attaching the mess to the hoops with hot
    glue, for different ways to install the electronics you can look them up online one site I would suggest you look up is
    www.edrums.info or Google search. Another way to look this up is go to youtube and type in DIY electronic drums in
    the search bar.
