Raspberry Pi Forum Pifacedigital2 Emulator
  • Subscribers 706 subscribers
  • Views 1539 views
ert1
ert1 over 7 years ago
I have installed pifacedigitalio however I am unable using the instructions provided by Piface to install the emulator.
Please can anyone help
Eric
    balearicdynamics over 7 years ago
    There are some issues if you try running the PiFace Digital2 (emulator and hardware) on the most recent Raspbian Linux distributions. One of these is that it no longer runs on Python 2.x but on the 3.x versions. Indeed, the installation of the Python libraries will work also for Python 2 so this creates a big confusion. The second issue is related to the SPI speed of the PiFace respect the default SPI speed of the Linux device. A detailed explanation on this problem and how you can solve it can be found in my blog post at the following link: Art-a-Tronic Episode 9
    Hope this maybe useful. Enrico
  • ert1
    ert1 over 7 years ago in reply to balearicdynamics
    Many thanks will try.
    Eric
    balearicdynamics over 7 years ago in reply to ert1
    Good. Let me know if you solve or if there are other issues again.
    Enrico
  • ert1
    have tried,  I changed the spi.py file.  It was in a different location to the one you suggested that it would be.
    pifacedigitalio installed OK,  using sudo install python3-pifacedigital-emulator I get unable to locate python3-pifacedigital-emulator.
    Any thoughts.
    Eric
    I think that for some reason that I don't know your setup is not standard. The location I suggested is in the path of the system. So I suggest you of trying two things. The first is calling the stuff with the full path and the second (especially if this first will work) adding the path to your system.
    Enrico
