Raspberry Pi 5 FAQs What is the pinout of the Raspberry Pi 5 40 pin header / block?
  • Subscribers 407 subscribers
  • Views 4164 views
  • Raspberry Pi 5 GPIO Pin Header
  • raspberry pi 5 gpio
  • Raspberry Pi 5 Pinout
  • raspberry pi 5
  • Raspberry Pi 5 40 Pin Header
cstanton
cstanton over 3 years ago
Is it the same as previous models of the Raspberry Pi? How does the RP1 change the GPIO?
  • cstanton
    +1 cstanton over 3 years ago
    The Raspberry Pi 5 GPIO Pinout for the 40-pin header is nearly identical to previous models of the Raspberry Pi.
    You can view more details here:  Raspberry Pi 5 Pinouts including GPIO for the 40 Pin Header
    The key difference with the Raspberry Pi 5 is that it now uses the RP1 Peripheral Controller. The first 28 GPIO on the RP1 is dedicated to the 40-pin header and matches nearly the same or similar functionality as on the previous Raspberry Pi. You can read more about the RP1 Peripheral Controller here:  RP1 Datasheet - Peripheral Controller Datasheet Draft
