    • Avnet Boards Community
Raspberry Pi Projects
Blog Measure the Analogue Front-end of Data Acquisition Board for Pi Pico
  • Date Created: 5 Nov 2023 12:05 PM Date Created
  • Views 1617 views
  • Likes 9 likes
  • Comments 11 comments
  • rpiintermediate
  • ADC (Analog-to-Digital Converter)
  • pico
  • data acquisition
  • ads1115
  • rp2040
  • daq
  • raspberry_pi_projects
  • adc
  • test&measurement
  • pi pico
5 Nov 2023
 shabaz designed a Data Acquisition Board (DAB ) for the Pico:  Data Acquisition Board for Pi Pico . In this post, I'll measure the analogue front-end, and show how it behaves within its +- 4V range.
I've attached probes to the main points of interest. Then applied input values between +4 V and -4 V, in steps of 0.5 V.
The data is collected in a spreadsheet to try and spot trends and stability.
Measurement points
1 5V supply power
2 3.3V supply power
3 GND supply power ground
4 AIN_1 test voltage input
5 AIN1_P opamp U1D out output
6 AIN1_N opamp U1B out virtual ground
Test results and calculations
  • The first 5 columns reflect the testing points of the previous chapter (without GND), and are all measured (in V).
  • diff: ainp - ainn, in essence, it is input * gain, measured
  • ain calc: diff * theoretical gain, (circuit gain, based on resistors used, is 0.38298), should ideally match ain
  • ain err: ain -  ain calc. How much does the calculated ain differ from the actual input
  • gain: what is the actual gain of U1D at each sample
Graphs and trends
Error
Let's first look at the error across the range:
This is very linear. and crosses at 0V input. That points to (discuss if you have a different opinion):
  • no offset error
  • the gain isn't 0,38298, but closer to 0.385
Here is the same graph if I set the gain for calculations to 0.385:
This is good news for calibration algorithms. Easy to program as a function. No lookup tables needed.
Gain
The gain is also consistent across the range. I blame the peak at 0 to calculation error factor (discuss). Everything is close to 0 at that point.
I did double-check the values though.
Here are all measurements:
image image
image image
image image
image image
image image
image image
image image
image image
image image
image image
And the spreadsheet:
8311.measure_analogue_frontend.ods.zip
  • ggabe
    ggabe over 1 year ago
    The question to me is now much gain accuracy is good enough, for a 3 1/2 digit instrument? We can answer that with an exact number, like 0.1% and +/- 1 LSB.
    I think TS9224 is not even close to it. No surprise, as TS9224 is a general purpose RRIO opamp, the data sheet does not even attempt to describe output swing close to rails or offset voltage dependency on the common mode voltage. A better suited opamp for analog frontend in the 5V RRIO category is OPA2325. I used it in my 5 1/2 digit DAQ. It has a well specified and very flat Vos vs Vcm function. Not saying it's a must, just to show a higher end part with no surprises.
    https://www.ti.com/lit/ds/symlink/opa2325.pdf?ts=1699132603600
  • ggabe
