      • Japan
      • Vietnam
Raspberry Pi
Raspberry Pi
Documents Raspberry Pi Model A versus Model B Chart
  • Author Author: joeman
  • Date Created: 10 Jan 2013 7:11 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 5:23 AM
  • Views 3134 views
Raspberry Pi Model ARaspberry Pi Model B
PriceFrom US$25From US$35
Ethernet/InternetNoYes
Dual USB ConnectorNoYes
512MB MemoryNoYes
Technical Features
ChipBroadcom BCM2835 SoC full HD multimedia applications processorBroadcom BCM2835 SoC full HD multimedia applications processor
CPU700 MHz Low Power ARM1176JZ-F Applications Processor700 MHz Low Power ARM1176JZ-F Applications Processor
GPUDual Core VideoCore IVRegistered Multimedia Co-ProcessorDual Core VideoCore IVRegistered Multimedia Co-Processor
Memory256MB SDRAM512MB SDRAM
EthernetNoneonboard 10/100 Ethernet RJ45 jack
USB 2.0Single USB ConnectorDual USB Connector
Video OutputHDMI (rev 1.3 & 1.4) Composite RCA (PAL and NTSC)HDMI (rev 1.3 & 1.4) Composite RCA (PAL and NTSC)
Audio Output3.5mm jack, HDMI3.5mm jack, HDMI
Onboard StorageSD, MMC, SDIO card slotSD, MMC, SDIO card slot
Operating SystemLinuxLinux
Dimensions8.6cm x 5.4cm x 1.5cm8.6cm x 5.4cm x 1.7cm
Visit the Raspberry Pi Group and Accessories Group for more activites and related products.
  • raspberry
  • pi
  • versus
  • b
  • chart
  • model
  • a
  • johnbeetem
    johnbeetem over 11 years ago in reply to Gough Lui +1
    Gough Lui wrote: Someone should probably make a newer version of this updated with the Pi A+ and B+ models. Pertinent changes include 4 USB 2.0 ports on B+, improved switching converters, expanded…
  • Gough Lui
    Gough Lui over 11 years ago
    Someone should probably make a newer version of this updated with the Pi A+ and B+ models. Pertinent changes include 4 USB 2.0 ports on B+, improved switching converters, expanded 40-pin GPIO with backwards compatible pin allocation, smaller size on A+, and change to microSD slot.
  • johnbeetem
    Here's a newer version started last July: http://www.element14.com/community/docs/DOC-68090/l/raspberry-pi-model-a-a-b-b-compute-module-dev-kit-comparison-chart
  • Gough Lui
    Gough Lui over 11 years ago in reply to johnbeetem
    Thanks for that, I didn't see it on a quick search image.
    - Gough
  • Gough Lui
    - Gough
