Raspberry Pi
Raspberry Pi
Documents Assembled Gertboard for Raspberry Pi
  • Author Author: joeman
  • Date Created: 17 Jan 2013 5:05 PM Date Created
  • Last Updated Last Updated: 10 May 2021 8:50 PM
  • Views 15996 views
  • Comments 43 comments
Buy NowBuy NowFeaturesUser ManualSoftwareApplicationsOther Raspberry Pi Accessories
Overview
Gertboard is the ideal add-on for Raspberry Pi. Designed by Gert van Loo, it is a flexible experimenter board that plugs directly into your Raspberry Pi, and out into the physical world, allowing you to detect and respond to external physical events. Detect and output analogue voltages. Drive powerful motors. Detect switch presses. Illuminate LEDs and drive relays. Jumper cables allow you to hook up different parts of the circuit in many different ways, allowing total flexibility. All controlled by your own Raspberry Pi.
Features:
  • Plugs directly onto Raspberry Pi GPIO socket
  • Motor controller, capable controlling a motor bi-directionally, delivering 18V and 2A maximum
  • Dual-channel D-to-A converter, 8-bit
  • Dual-channel  A-to-D converter, 10-bit
  • Onboard Atmel ATmega328ATmega328 MCU for running off-board programmes which are written, compiled and uploaded to Gertboard from Raspberry Pi
  • 6 x open collector outputs
  • 12 x LED indicators
  • 3 x momentary push switches
  • 10 x strap cables included
  • 18 x jumpers included
  • Software and manuals available to operate and learn how to use Gertboard
Back to top
Key Applications
  • Experimentation
  • Home burglar alarm
  • Motor control
  • Sensor detection and control
  • Educational applications
Back to top
  • raspberry
  • pi
  • raspberry_pi
  • for
  • assembled
  • gertboard
    Morning,
    Is the 24pin ribbon cable to connecto rpi not included with this?
    Thanks
    Tom
  • joeman
    joeman over 13 years ago in reply to arajnak
    Thx Antal:
    You can now find the missing schematics here:
    http://www.element14.com/community/docs/DOC-52867
    Or via a newly added tab "Schematics" within this doc.
    Hopefully that helpsimage
  • arajnak
    arajnak over 13 years ago
    Hi,
    1. Appendix with the schematics is missing from the UserManual Rev. 2.0
    2. Suggest to add release date, or version info on the front page (e.g. 2_0_A) for easy identification of the printed doc. (Rev 1.0 did exist in multiple versions, only the filename carrying the version info, e.g. _F). Inserting a Release History section would be even better.
    Thanks for the many improvements in Rev. 2.0.
    cheers
    Antal
