Raspberry Pi
Raspberry Pi
Documents Assembled Gertboard for Raspberry Pi
  • Author Author: joeman
  • Date Created: 17 Jan 2013 5:05 PM Date Created
  • Last Updated Last Updated: 10 May 2021 8:50 PM
  • Views 15994 views
  • Comments 43 comments
Buy NowBuy NowFeaturesUser ManualSoftwareApplicationsOther Raspberry Pi Accessories
Overview
Gertboard is the ideal add-on for Raspberry Pi. Designed by Gert van Loo, it is a flexible experimenter board that plugs directly into your Raspberry Pi, and out into the physical world, allowing you to detect and respond to external physical events. Detect and output analogue voltages. Drive powerful motors. Detect switch presses. Illuminate LEDs and drive relays. Jumper cables allow you to hook up different parts of the circuit in many different ways, allowing total flexibility. All controlled by your own Raspberry Pi.
Features:
  • Plugs directly onto Raspberry Pi GPIO socket
  • Motor controller, capable controlling a motor bi-directionally, delivering 18V and 2A maximum
  • Dual-channel D-to-A converter, 8-bit
  • Dual-channel  A-to-D converter, 10-bit
  • Onboard Atmel ATmega328ATmega328 MCU for running off-board programmes which are written, compiled and uploaded to Gertboard from Raspberry Pi
  • 6 x open collector outputs
  • 12 x LED indicators
  • 3 x momentary push switches
  • 10 x strap cables included
  • 18 x jumpers included
  • Software and manuals available to operate and learn how to use Gertboard
Back to top
Key Applications
  • Experimentation
  • Home burglar alarm
  • Motor control
  • Sensor detection and control
  • Educational applications
Back to top
  • raspberry
  • pi
  • raspberry_pi
  • for
  • assembled
  • gertboard
  • joeman
    joeman over 13 years ago in reply to e14 Contributor
    Doesn't look like it is available in China yet.  But it is available in Singapore:
    http://sg.element14.com/jsp/search/productdetail.jsp?sku=2250034&COM=embedded-link_RaspberryPiAccessories
    and in Hong Kong:
    http://hk.element14.com/jsp/search/productdetail.jsp?sku=2250034&COM=embedded-link_RaspberryPiAccessories
    Any further ordering questions, You can go to our "Feedback and Support" page and post a question there.
    I'm in China, can I buy this though this site? when to start?
    Hi
    Where can you buy the Gertboard ?
    Farnell here in denmark dont sell to privates???!!!!S...
    Jan
  • captainofspray
    captainofspray over 13 years ago in reply to e14 Contributor
    I'm pretty sure the Coocox software is just an alternative way of programming the Atmega chip on the Gertboard. You can instead run the normal Arduino software on the Pi via SSH. [Someone correct me if I've misunderstood that].
    Have you found the Gertboard User Manual? The test programs it talks about are already available in both C and Python,for free download. They look to me like the backbone of whatever I'm going to  write for myself.
    Does the software support CD (Coocox) only work for Windows? I have a Mac and have been running the pi thru ssh.. I am not about to purchase a Microsoft computer solely for the gertboard but it seems silly that the only software support would be windows based. I feel like I'm missing something?
  • captainofspray
    Features tab says "Plugs directly onto Raspberry Pi GPIO socket". No, you can't do that, because the other end of the Gertboard touches the metal housing of the Ethernet socket.
    I agree with tomgwb1, a suitable ribbon cable should have been included in the kit.
    Even more annoying, I can't find a suitable cable on the Farnell website (that noise? That's me grinding my teeth).
    Otherwise, I find the Gertboard seriously interesting and I'm longing to try some stuff out.
  • epmueller
    epmueller over 13 years ago
    David,
         I ended up using a 90 degree double-row connector mounted on the bottom of the Gertboard replacing the female socket.  Since I will be mounting the Gertboard to an acrylic plate using nylon standoffs (thus the query above regarding the drilling template) this avoids obscuring anything on the top of the Gertboard and still utilizes a female-female IDC ribbon cable.
  • epmueller
    Is there a mounting template drawing available for the Assembled Gertboard?  It would be useful to have a full scale drawing of the mounting hole locations relative to the edge of the printed circuit board for mounting on something besides directly to the Raspberry Pi's GPIO connector.
  • zed_thirteen
    zed_thirteen over 13 years ago in reply to epmueller
    I agree with Edward.  That underside connector is no use to anyone who has their Pi housed in a case.
    IDC ribbon cable headers (male) are very expensive.  I will have to remove the socket from the underside of mine and install a male header topside.
    Is it possible to get sockets with elongated legs so it could facilitate both male and female options?
  • epmueller
    I sure that some of us would perfer to connect the Gertboard via a standard (female-female) IDC ribbon cable instead of plugging it directly into the RasPi's GPIO connector.  It would have been useful to either have a user installed J1 connector so that the sex of the connector could be easly changed or a male connector installed.  It would relieve the effort of removing (unsoldering) the bottom-facing female connector prior to installing the desired sex (male) connector.
    Also, it would be nice to offer an additional product in the for of an acrylic plate, slightly larger than the Gertboard, with pre-drilled mounting holes to mount the Gertboard to.  This would allow the Gertboard to be placed directly on the workbench.
