Raspberry Pi
Raspberry Pi
Documents Introducing the Raspberry Pi Zero
  • Author Author: joeman
  • Date Created: 23 Nov 2015 7:28 PM Date Created
  • Last Updated Last Updated: 1 Mar 2016 5:24 PM
  • Views 21061 views
  • Likes 20 likes
  • Comments 91 comments
Raspberry Pi Zero
This ultra-small and ultra-slim Raspberry Pi board is the smallest form factor Raspberry Pi on the market today at only 65mm long by 30mm wide and 5mm deep. The board supports mini connectors to save on space, and the 40pin GPIO is unpopulated providing the flexibility to use only the connections your solution requires.image
Features
  • Broadcom BCM2835 ARMv6  system-on-a-chip, running at up to 1GHz
  • 512MB on-board RAM
  • Unpopulated 40pin GPIO for added flexibility
  • MicroSD port for OS and storage
  • Micro USB power input
  • 1x Micro USB Data port and Mini HDMI Port
(comes with Micro USB ‘On the Go’ adapter and Mini HDMI to HDMI adapter)
Buy Now
Raspberry Pi Zero  SOLD OUT
Raspberry Pi Zero & NOOBS MicroSD Card SOLD OUT
Raspberry Pi Zero BoardRaspberry Pi Zero Board
Mini-HDMI to HDMI AdapterMini-HDMI to HDMI Adapter
Micro USB "On the Go" to USB AdapterMicro USB "On the Go" to USB Adapter
8GB MicroSD Card Pre-Loaded with NOOBS
MicroSD to SD Card Adapter
Raspberry Pi Zero on element14
Want to learn more about the Pi Zero and what it can do? Check out our exclusive coverage right here at element14.
Overview of the Raspberry Pi Zero
Get all the facts about the smallest, slimmest Raspberry Pi in one page. Everything you need to know about the Zero.
Five Things You Need to Know About the Raspberry Pi Zero
You're bound to have a bunch of burning questions about the Zero, so we've answered the most common ones right here.
Raspberry Pi Zero Comparison Chart
Curious about how the Raspberry Pi Zero stands up alongside the rest of the fruitful family of single board computers? Here's a comparison chart.
Raspberry Pi Zero Retro Gaming System
Our first ultra-slim Pi project inside a big, fat, retro TV. We turn the Raspberry Pi Zero into a retro gaming hero -- and so can you by following our build along project.
  • raspberry pi zero
  • raspberry_pi
  • raspberry pi
  • pi_zero
  • raspberrypi
  • pi zero
  • fvan
    fvan over 10 years ago in reply to spannerspencer +8
    Sure thing:
  • Workshopshed
    Workshopshed over 10 years ago in reply to Workshopshed +7
    Some enhancements, note that the dimensions still need checking
  • fvan
    fvan over 10 years ago +7
    Made my own little mod While piggy-back wifi is nice, piggy-back USB hub is even better: The Pi is powered by the USB hub, and up to 4 dongles can be connected. Using low profile dongles keeps everything…
  • Workshopshed
    I took the advice of the Adafruit guy and built a simple model of the PiZero to check the dimensions against. I think this is as far as I can get without a board so I'll wait for my deliver before finalising things. In the mean time if anyone who has a board fancies doing a test print I'd be glad to hear what needs fixing. Latest STLs are at https://github.com/Workshopshed/3DPrinting/tree/master/PiZeroCase
  • fvan
    Excellent tutorial on making an enclosure for the Zero, from Adafruit:
    • Vote Up +5 Vote Down
  • SGarciaV
    SGarciaV over 10 years ago in reply to balearicdynamics
    I agree. When I got my RPi 2B I installed the Raspian using the Noobs SD card that came with the starter kit. I got an error every time when booting up Linux. It wasn't until I connected the Pi o my LAN that it installed and booted correctly.Connectivity is required. I would imagine that there would be lots of information detailing how to get connected, either with WiFi or Ethernet, as I see this more important on the Pi-Zero than, for example, the HDMI output.
  • Workshopshed
    Workshopshed over 10 years ago in reply to bwelsby
    Thanks bwelsby that appeared in my twitter feed a few minutes ago. It's got the majority of what I need but I'll have to get the socket widths off the web, hope to sort it out this evening. Also these might need some fine tuning to allow for the size of connectors being inserted into the sockets. I've added some feet and re-enforced the mounting points.
  • bwelsby
    bwelsby over 10 years ago in reply to Workshopshed
    In case you haven't found it yet full dimension details are here :- https://www.raspberrypi.org/documentation/hardware/raspberrypi/mechanical/rpi-zero-v1_2_dimensions.pdf
  • spannerspencer
    spannerspencer over 10 years ago in reply to Workshopshed
    Nice work! It's a small device, so a neat case like this would be great -- especially if you were thinking of going portable with it.
  • Workshopshed
    • Vote Up +7 Vote Down
    I thought it was supposed to be $5.00???
  • bwelsby
    bwelsby over 10 years ago in reply to rew
    Roger Wolff wrote:
    Generally speaking, when you order when there is stock you'll be one of the people who get an item from said stock!
    This does not hold when one way or another your order takes a long time to go to "payment completed" status.
    I agree, I had a similar problem when the RPi2 was released, I placed my order on-line with Farnell when it showed in stock but by the time they got to processing it they had sold out. I was told that there was a lag between the website updates and telephoned orders and trade counter sales.
    Anyhow the good news is that my CPC order is now showing completed so I shall clear some space for the new arrival image
  • gadget.iom
    gadget.iom over 10 years ago in reply to bwelsby
    Thanks for the head-up bwelsby!
    Just placed an order image
