Raspberry Pi
Raspberry Pi
Documents Introducing the Raspberry Pi Zero
  • Author Author: joeman
  • Date Created: 23 Nov 2015 7:28 PM Date Created
  • Last Updated Last Updated: 1 Mar 2016 5:24 PM
  • Views 21060 views
  • Likes 20 likes
  • Comments 91 comments
Raspberry Pi Zero
This ultra-small and ultra-slim Raspberry Pi board is the smallest form factor Raspberry Pi on the market today at only 65mm long by 30mm wide and 5mm deep. The board supports mini connectors to save on space, and the 40pin GPIO is unpopulated providing the flexibility to use only the connections your solution requires.image
Features
  • Broadcom BCM2835 ARMv6  system-on-a-chip, running at up to 1GHz
  • 512MB on-board RAM
  • Unpopulated 40pin GPIO for added flexibility
  • MicroSD port for OS and storage
  • Micro USB power input
  • 1x Micro USB Data port and Mini HDMI Port
(comes with Micro USB ‘On the Go’ adapter and Mini HDMI to HDMI adapter)
Buy Now
Raspberry Pi Zero  SOLD OUT
Raspberry Pi Zero & NOOBS MicroSD Card SOLD OUT
Raspberry Pi Zero BoardRaspberry Pi Zero Board
Mini-HDMI to HDMI AdapterMini-HDMI to HDMI Adapter
Micro USB "On the Go" to USB AdapterMicro USB "On the Go" to USB Adapter
8GB MicroSD Card Pre-Loaded with NOOBS
MicroSD to SD Card Adapter
Raspberry Pi Zero on element14
Want to learn more about the Pi Zero and what it can do? Check out our exclusive coverage right here at element14.
Overview of the Raspberry Pi Zero
Get all the facts about the smallest, slimmest Raspberry Pi in one page. Everything you need to know about the Zero.
Five Things You Need to Know About the Raspberry Pi Zero
You're bound to have a bunch of burning questions about the Zero, so we've answered the most common ones right here.
Raspberry Pi Zero Comparison Chart
Curious about how the Raspberry Pi Zero stands up alongside the rest of the fruitful family of single board computers? Here's a comparison chart.
Raspberry Pi Zero Retro Gaming System
Our first ultra-slim Pi project inside a big, fat, retro TV. We turn the Raspberry Pi Zero into a retro gaming hero -- and so can you by following our build along project.
  • raspberry pi zero
  • raspberry_pi
  • raspberry pi
  • pi_zero
  • raspberrypi
  • pi zero
  • fvan
    fvan over 10 years ago in reply to spannerspencer +8
    Sure thing:
  • Workshopshed
    Workshopshed over 10 years ago in reply to Workshopshed +7
    Some enhancements, note that the dimensions still need checking
  • fvan
    fvan over 10 years ago +7
    Made my own little mod While piggy-back wifi is nice, piggy-back USB hub is even better: The Pi is powered by the USB hub, and up to 4 dongles can be connected. Using low profile dongles keeps everything…
  • bwelsby
    bwelsby over 10 years ago in reply to Problemchild
    John Alexander wrote:
    Mine didn't come from CPC.. not happy as they said it was complete
    Same here, I got all excited when the postman walked down our path, but nothing for me image
  • Problemchild
    Problemchild over 10 years ago in reply to johnbeetem
    Do you think that the connectors offered any effective cooling John. The hotest think onthe board when I did the thermal imaging was the NIC/HUB chip which is now of course missing.
  • Problemchild
    Problemchild over 10 years ago in reply to Workshopshed
    Mid you Andy in both cases they have all but obscured the SOC... I can't see effective air cooling from the air falling in that little pit in the case thus the Heatsink.
    Besides it makes it look cool
  • johnbeetem
    johnbeetem over 10 years ago in reply to hareeshgs
    Hareesh GS wrote:
    Somebody who own this can post a review? Performance with 1080p? My concern is about the RAM as compared to Pi2. Heating of SoCs if any? Element14 India shows 'SOLD OUT" !.
    Heat should be about the same as a Model A+ or B+ (if you don't use USB or Ethernet).  The Zero is simply a stripped-down Model A+/B+: same SoC, 512MB, but no LAN chip.  On the other hand, the Zero doesn't get cooling from the full-size USB, HDMI, and Ethernet (in the case of B+) connectors.  In a CPU or memory-intensive application like a media box, you might need a heat sink.
  • Problemchild
  • Workshopshed
    Workshopshed over 10 years ago in reply to hareeshgs
    I have seen examples of cases involving heatsinks which does suggest a heating issue.
  • hareeshgs
    hareeshgs over 10 years ago
  • Workshopshed
    Workshopshed over 10 years ago in reply to spannerspencer
    Yup, I've used thanks and a board arrived in the post this morning.
  • spannerspencer
    spannerspencer over 10 years ago in reply to Workshopshed
    Nice! Did you see that we have some mechanical drawings now too, Andy? Might be useful in the interim?
    Raspberry Pi Zero - Technical Details
    balearicdynamics over 10 years ago in reply to Workshopshed
    Great job !
