Raspberry Pi
Raspberry Pi
Documents Raspberry Pi Plays Really Well with Others - Top 10 Best Friends
  • Author Author: jwatson
  • Date Created: 8 Mar 2016 6:17 PM Date Created
  • Last Updated Last Updated: 10 May 2021 8:51 PM
  • Views 1951 views
  • Comments 9 comments
Friend or Foe - let's just talk about friends...
Have you ever wondered what other components and software work well with Raspberry Pi?
Well, in short, probably most things, but to advertise the fact that this truly selfless board is happy to work with other well known parts, we decided to give a shout out to its best known friends it relishes hosting!
Product DescriptionInstructions
Arduino Leonardo / Uno
The Pi can communicate with the board to enable realtime actions, additional inputs and other functionality.
View the Connecting an Arduino to a Raspberry Pi Project
CadSoft Eagle
There are Raspberry Pi CadSoft libraries for the Pi and Compute, along with the ability to design add on boards.
View the Raspberry Pi 2 CadSoft Library
View the Raspberry Pi Compute Module Development Kit CadSoft Library
View the Pi HAT Project (Pi 2 + Eagle)
chipKITimage Pi
The world's first to enable the development of 3.3V Arduino compatible applications for the Raspberry Pi using a 32bit, high performance PIC32 MCU in a prototyping friendly package.
Cirrus Logic Audio Card
Adds high quality audio recording, and playback to the Pi.
Learn More
View Outdoor Audio Recorder Project
CodeBug
A fun, low-cost, programmable wearable device that anyone can learn to use.
View 10 Projects in 10 Days Blog
Embedded Pi
A triple play platform for Raspberry Pi, Arduino and 32bit embedded ARM. Blending all three communities together, Embedded Pi helps to get the most out of each platform.
FPGA Development Board
Allows people to create a customised microprocessor.
Learn More
Explore An Introduction, Documents and Tools
Gertboard
Uses an ATMega328P which is the same chip as on the Arduino Uno.
Learn More
Spraying and Weeding Systems Paired with an Autonomous Lawn Mower Project
GertDuino
Arduino and Arduino Uno compatible GPIO expansion board.
Learn More
Raspberry Pi RTC Shim
Adds a real time clock to the Raspberry Pi.
Learn More
Why not buy your Raspberry Pi a present?
We Carry Accessories for All Versions of Raspberry PiView Accessories
  • codebug
  • fruitful_three
  • cadsoft eagle
  • shim
  • chipkit
  • raspberry_pi
  • pi3
  • raspberry pi
  • top10_raspberrypi_parts
  • raspberry pi accessories
  • leonardo
  • pfga
  • gertboard
  • cirrus logic audio card
  • anniel747
    anniel747 over 3 years ago
    Cool.
    Liénard–Wiechert potentials describe the classical electromagnetic effect of a moving electric point charge in terms of a vector potential and a scalar potential in the Lorenz gauge.
    electronic decree
    electronic decree
  • gordonmx
    gordonmx over 10 years ago
    Decree! Decree! My kingdom for an "electronic decree".
  • tonyboubady
    tonyboubady over 10 years ago
    Coulomb's law or Coulomb's inverse-square law, is a law of physics that describes force interacting between static electrically chargedparticles. In its scalar form the law is:
    image ,
  • ipv1
    ipv1 over 10 years ago
    Faraday's law states that the EMF is also given by the rate of change of the magnetic flux:
    image,
    where image is the electromotive force (EMF) and ΦB is the magnetic flux. The direction of the electromotive force is given by Lenz's law.
  • ipv1
    Kirchoff's Voltage rule: The sum of all voltages or potential differences in an electrical circuit loop is 0.
  • ipv1
    The ChipKit was not exactly a walk in the park for the most part. Clunky programming system and not recommended for the beginners.
    Hats off to the Gertboard. Very versatile...
