Raspberry Pi
Raspberry Pi
Documents Setting up Bluetooth on the Raspberry Pi 3
  • Author Author: cstanton
  • Date Created: 16 Mar 2016 1:01 AM Date Created
  • Last Updated Last Updated: 10 May 2021 7:23 PM
  • Views 17509 views
  • Likes 18 likes
  • Comments 61 comments
Wireless at Last!
Now that it has been a few weeks since the release of the Raspberry Pi 3Raspberry Pi 3, support for the WiFi and Bluetooth chip has settled and you can use it with Raspbian. Support with Windows 10 IoT Core will be available in the early days via the Insider Program before it is pushed through to the full release.
As usual, with Raspbian ensure that you have your distribution up to date, with this guide we will be using Raspbian Jessie, at present it is still the ARMv7 32bit kernel. Connect your Raspberry Pi to the internet either via WiFi or Ethernet and run the following commands:
sudo apt-get update
sudo apt-get upgrade -y
sudo apt-get dist-upgrade -y
sudo rpi-update
Installing the Software
From a console terminal, either from within your desktop environment, which at the time of writing the window manager is still LXDE. This will ensure your system is up to date.
Now you have a few options, you can install the following package:
sudo apt-get install pi-bluetooth
Which should install what you need to use the bluetooth portion of the chip, this installs the following packages which you can, if you want, install instead of pi-bluetooth:
sudo apt-get install bluez bluez-firmware
As the chip requires a firmware blob to work along with the driver. Bluez also installs a suite of tools. These will work from the console terminal. Should you wish to manage your bluetooth devices from your X environment, aka your windows manager, aka your desktop then you can install the following package:
sudo apt-get install blueman
After installing the software and drivers, reboot your Raspberry Pi. Unless you know otherwise, to load the driver for the adapter.
Terminal / Console
Bluez comes with a tool called 'bluetoothctl' which you can run from the console terminal, typing 'man bluetoothctl' does not give you a great deal of detail, so you have to type 'help' from within the software:
pi@raspberrypi:~ $ bluetoothctl
[bluetooth]# help
Available commands:
  list                       List available controllers
  show [ctrl]                Controller information
  select <ctrl>              Select default controller
  devices                    List available devices
  paired-devices             List paired devices
  power <on/off>             Set controller power
  pairable <on/off>          Set controller pairable mode
  discoverable <on/off>      Set controller discoverable mode
  agent <on/off/capability>  Enable/disable agent with given capability
  default-agent              Set agent as the default one
  scan <on/off>              Scan for devices
  info <dev>                 Device information
  pair <dev>                 Pair with device
  trust <dev>                Trust device
  untrust <dev>              Untrust device
  block <dev>                Block device
  unblock <dev>              Unblock device
  remove <dev>               Remove device
  connect <dev>              Connect device
  disconnect <dev>           Disconnect device
  version                    Display version
  quit                       Quit program
Now we are in bluetoothctl we can run the commands, first lets make sure that bluetooth is on, running and discovering devices:
With the commands 'power on', 'agent on' and 'scan on'. Though we likely only need 'power on' and 'scan on'.
Devices! and while the software is running we will see devices appear, change, delete, etc. We can then connect to a device using its MAC address. Basically, we are talking to the devices directly at the hardware layer, usually on your typical WiFi or Ethernet network this is done transparently to you and we only work with IP addresses. However with Bluetooth at this point, no.
We can also then pair and trust the device and do all the fun features of Bluetooth, provided these are successful.
GUI
Some consider the blueman package and software to be unstable, though the sources saying so are a bit dated by now and it may be somewhat more stable.
When you have the blueman package installed, you should have a nice Bluetooth icon in your system tray. If you left-click with a mouse connected to your Raspberry Pi you should get a menu with all of the, hopefully, self explanatory options for you to play with, which for some reason I could not capture with scrot/imagemagick, so you get a nice photograph:
Yum, pixelated (it was an old Dell monitor). If we want to scan for devices, similarly to using the 'scan' command for bluetoothctl then we select 'Devices' on the menu:
And from here we can see what is available in the vicinity, you may be surprised at suddenly finding your neighbours smart television or phone, you will find out how thin your walls really are. It can be more fun in the office at work.
However, let us select "setup a new device":
{gallery} Add New Device
Add New Devices: Introduction
Add New Device: Choose the Device to Connect to
Add New Device: Choose a pairing code
However, what I discovered is that the passkey method is practically deprecated or ignored, it may be applicable for older Bluetooth software or devices, but these days you will get a prompt appear (and for myself, then hide) on Raspbian, next to the icon for blueman, there will be a message, and in this message it will display a message like:
This device wants to pair with this machine, with this code xxxxxxxx, do you want to permit or deny?
This likely happens with new devices such as smart phones and televisions, as a security measure that you are physically holding or looking at the device in question. Of course you then 'permit' on either the device or Raspbian and the two will be paired. Allowing you to then setup drivers for your Bluetooth device functionality, to use it as a modem, in the case of a phone, share its internet access or simply send files to and from it. Potentially, you can even use it as an audio device!
Attaching to devices such as headsets tends to be easier, and usually does not use a pairing code. A standard is usually four zeroes (0000) with most consumer devices.
Have you setup your Raspberry Pi 3 with Bluetooth?
Perhaps speakers, or even the Panasonic Grid Eye sensor boardPanasonic Grid Eye sensor board? (yes, it has bluetooth). I am not sure what I will do with mine, but after I backed the Bluetooth Audio Link I may use it with some speakers, or perhaps add the functionality to remote control a Plex Server.
  • bluetooth
  • ble
  • raspberry pi 3 bluetooth
  • ble 4.0
  • bluetooth low energy 4.0
  • ble 4.1
  • raspberry_pi
  • bluetooth_4.1
  • raspberry pi
  • bluetooth 4
  • bluetooth 4.1
  • raspberry_pi_space
  • raspberry_pi_3_bluetooth
  • bluetooth 4.0
  • raspberry pi 3
  • ble_4.1
    shabaz over 10 years ago +3
    Nice! I just tried it - worked a treat with my keyboard following your instructions. The update/upgrade part is super important, I tried it first without that (I was curious lol). After the upgrade, I…
    shabaz over 10 years ago +2
    Also, cool smartphone name ; )
  • bwelsby
    bwelsby over 10 years ago in reply to cstanton +2
    Christopher Stanton wrote: So just for clarification, you're pairing more than one device at once to the Raspberry Pi? Yep and playing music from one device through the RPi to the other BTW another cause…
  • colporteur
    colporteur over 7 years ago in reply to soumenn@analyticsplus.com
    G'Day,
    I can see why you would be experiencing problems using just the details from this site. Much has changed since this posting. I found the following reference
    Bluetooth Audio with Rasbian Stretch on the Raspberry Pi 3
    https://www.sigmdel.ca/michel/ha/rpi/bluetooth_02_en.html
    May 14, 2018
    to be the most comprehensive for getting a reliable bluetooth connection. Checkout other bluetooth updates and resources at the link. I just completed the procedure and confirm it works. I am available as a resource if needed.
    Sean
  • soumenn@analyticsplus.com
    soumenn@analyticsplus.com over 7 years ago
    Hello
    I go through the above all setup and installation I am getting continuously one error (Failed to connect: org.bluez.Error.NotAvailable) and currently I am Using raspberrypi3 b+ it has own bluetooth so i am trying to connect with another bluetooth  hc05 for bi direction communication for sending some data
    connect 00:18:E4:40:00:06
    Attempting to connect to 00:18:E4:40:00:06
    [CHG] Device 00:18:E4:40:00:06 RSSI: -71
    [CHG] Device 00:18:E4:40:00:06 Connected: yes
    [CHG] Device 00:18:E4:40:00:06 ServicesResolved: yes
    [CHG] Device 00:18:E4:40:00:06 ServicesResolved: no
    [CHG] Device 00:18:E4:40:00:06 Connected: no
    [CHG] Device D8:5D:E2:CD:CD:40 RSSI: -63
    [CHG] Device 00:18:E4:40:00:06 RSSI: -61
    I am not able to fine any solution for this
  • jrm123
    jrm123 over 8 years ago in reply to e14 Contributor
    hello Sir,
    I too have a vizio XRA700 remote.  it is a beauty.
    have you had any additional success with this remote ?
    you mentioned " pairing mode "  I was not aware there was such a method, how did you make this work ?
    I know this is an ancient thread but I still have this remote and would love to use it for my car pc project.
    Thank you.
    Best
    JRM123
  • robertspil
    robertspil over 8 years ago
    Important: the Raspbian Strecht light (september 2017) does NOT recognize the bluetooth controler of a Pi3B or Zero W.
    The internal bluetooth controler is not recognized by bluetoothctl , altough hciconfig does.
    You have to install blueman....and this add "something" needed by the  command-line tools.
  • waterbound
    waterbound over 9 years ago
    Note for those running Kodi using Xbian OS on Pi3, in Kodi, go into system, Xbian then services and select AD2P then install.
    Reboot the pi3 and go back into Kodi, system, Xbian and Bluetooth will be near the bottom, select and pair with your BT device as normal.
  • clem57
    clem57 over 9 years ago in reply to diliprajkumar
    diliprajkumar look at  Bluetooth Network - eLinux.org
  • diliprajkumar
    diliprajkumar over 9 years ago
    I setup bluetooth on the pi and paired my Windows Laptop to it, now how do i start controlling the Pi3's terminal screen via PUTTY on my windows laptop? Or how can i control the Pi3 on my android smartphone via Bluetooth...can i make this setup on the RPi 3 so that i get terminal screen control via bluetooth when the RPi3 boots?
  • gotojom@gmail.com
    gotojom@gmail.com over 9 years ago
    How many people actually paired RPI 3 with Android phone? Low percentage mean software not stable/predictable. I couldn't get working after a day with GUI/CHUI interfaces.
  • timbaktoo
    timbaktoo over 10 years ago
    How to configure RPi3 as a BLE Device ?
  • cstanton
    cstanton over 10 years ago in reply to rive
    Bluez is shipped by default now.
