Raspberry Pi
Raspberry Pi
Documents Raspberry Pi - Pi400 - All in One Raspberry Pi, Keyboard and Mouse Computer
  • Author Author: e14phil
  • Date Created: 23 Oct 2020 1:49 PM Date Created
  • Last Updated Last Updated: 3 Nov 2020 9:53 AM
  • Views 7175 views
  • Likes 20 likes
  • Comments 12 comments
Introducing the New Raspberry Pi  - Raspberry Pi400image
Fully enclosed RPi 4 based desktop computer with all the connectivity of a Raspberry Pi 4
The Kit includes RPi 400, Power supply, Mouse, SD card (pre-programmed), beginners guide, 1 x micro HDMI cable
Buy Raspberry Pi 400 Kit HereBuy Raspberry Pi 400 Kit Here
Buy Raspberry Pi 400 ONLY HereBuy Raspberry Pi 400 ONLY Here
Fully enclosed RPi 4 based desktop PC
  • Higher clock speed to 1.8GHz
  • 4GB LPDDR4 RAM
  • 2.4GHz and 5.0 GHz IEEE 802.11 B/G/N/AC Wirless Lan
  • Bluetooth 5.0 BLE
  • Gigabit Ethernet
  • 2 x USB 3.0 Ports
  • 1 x USB 2.0 Port
  • 40-Pin GPIOP
  • 2 x Micro-HDMI Ports (Up to 4k60)
  • Micro SD Slip
  • Kensington Lock
  • Size 286 mm × 122 mm × 23 mm (maximum)
  • Available in kit form for $100 in 6 keyboard languages
  • Available in unit only for $70 in 6 keyboard languages
  • Manufactured at Sony, UK
Back Panel connectivity
Back Panel Connectivity Diagramimage
Keyboard Options
UK, US, Germany, France, Italy, Spain Keyboard options.
French Layout Example
Kit or or on its own!
The Raspberry Pi 400 Comes as a Kit with:
  • The Official Raspberry Pi Beginners Guide,
  • Raspberry Pi Mouse
  • SD Card
  • HDMI Cable
  • Power Supply
Or buy it on its own!
A truly out of box computing experience with all the connectivity of the Raspberry Pi
  • pi400
  • rpi 400
  • raspberry pi keyboard
  • raspberry pi 400
  • rpi400
  • raspberry pi 4
  • raspberry pi
  • raspberry pi mouse
  • gpolder
    gpolder over 6 years ago +6
    very interesting, this reminds me of my childhood, with Apple II, Sinclair ZX80/81, Spectrum, Tandy TRS80, Comodore VIC20, C64 etc. etc. All computers in a keyboard housing, with IO headers at the back…
  • koudelad
    koudelad over 6 years ago +4
    I am curious to see a teardown of this device to see how is the thermal management solved. RPi 4 can get very hot. On the other hand, it is very comfortable to write on a warn keyboard during the cold…
    shabaz over 6 years ago in reply to koudelad +4
    Hi David, I saw in a YouTube video yesterday that it's a large (keyboard-sized) thin stamped sheet of aluminium, taped to the BCM.. chip and overall screwed onto the plastic chassis (industrial products…
  • jkutzsch
    jkutzsch over 5 years ago in reply to koudelad
    Here is a review I appreciated that tore it down and explained the heatsink from JeffGeerling.com
    Cut and paste from his review with the full link below:  "
    Pi 400 Performance
    One thing you might notice in the Pi 400's specs is a new, higher default clock speed than you get with the year-old Pi 4 model B.
    It's clocked at 1.8 GHz out of the box, while the Pi 4 model B is clocked at 1.5 GHz.
    In some quick Phoronix benchmarks, the Pi 400 performed about 18% faster than the Pi 4 model B at the higher clock speed... which is expected, since that's the same ratio as the increase in megahertz.
    But how is this higher clock possible? Well, not only is the massive heatsink helpful here—the Pi 400 didn't overheat even when I was running it with an overclock to 2.147 GHz, the maximum it allows currently—but the actual BCM2711 chip is different in this model:
    https://www.jeffgeerling.com/blog/2020/raspberry-pi-400-teardown-and-review
    I so want to get my hands on one of these and test it out!  This screams customize a Cyberdeck to me!
    Hi David,
    I saw in a YouTube video yesterday that it's a large (keyboard-sized) thin stamped sheet of aluminium, taped to the BCM.. chip and overall screwed onto the plastic chassis (industrial products would do it very much differently but that's a different use-case).
    I think even if there was zero heatsinking it will self-protect itself if it needs to by reducing speed. I have a couple of Pi 4 boards that run permanently with zero heatsinking, they seem fine in an enclosure with some air vents, as you say nice and warm! but I don't do any heavy processing.
  • koudelad
    I am curious to see a teardown of this device to see how is the thermal management solved. RPi 4 can get very hot. On the other hand, it is very comfortable to write on a warn keyboard during the cold season image
    Very cool : )
    It has a very retro feel (in a nice way) and definitely simplifies things to get going.
    Plus it is barely more expensive than a regular Pi + heatsink + case, and a much tidier-looking solution, so almost a no-brainer to purchase this over the regular Pi, even if the keyboard portion isn't frequently used (after all, people do the same with laptops.. attach their own external keyboards and monitors).
    I'm guessing the 40-way connector is back-to-front so that a ribbon cable will correct it for any boards to plug in (in which case hopefully the bundled book etc might mention it, otherwise people might start wiring in stuff directly to the port, assuming it's numbered exactly like the earlier Pi boards).
    DAB over 6 years ago
    I noticed that it was already out of stock.
  • gpolder
    All computers in a keyboard housing, with IO headers at the back, and a connection to a television (NTSC/PAL).
    • Vote Up +6 Vote Down
  • stevaras
    stevaras over 6 years ago
    nice!
  • fmilburn
    fmilburn over 6 years ago
    I definitely want one!
  • geralds
    geralds over 6 years ago
    It's a fine thing.
    But the keyboard... hm....
    At school I learned to write on the typewriter, oh yes, in English and German.
    I write pretty fast now, but here ... ???  Where are !!!! the character ??? ----
    "They seem to have been rolled here."
    https://en.wikipedia.org/wiki/AZERTY
    https://en.wikipedia.org/wiki/QWERTY
    Do you really think I'm going back to school?  image
  • feiticeir0
    feiticeir0 over 6 years ago
    What will the Raspberry PI guys invent next ? A rocket ship controlled by a Raspberry PI ? image
    It's a wonderful idea - not new, but a wonderful idea. I'll get one when the keyboard layout will be available in PT Qwerty .
