Raspberry Pi
Raspberry Pi
Documents Raspberry Pi 7” Touchscreen Display
  • Author Author: joeman
  • Date Created: 11 Aug 2015 6:55 PM Date Created
  • Last Updated Last Updated: 16 May 2022 10:17 AM
  • Views 116451 views
  • Likes 20 likes
  • Comments 478 comments
Buy Here  Display Installation Guide
Install Virtual Keyboard* Other Pi Accessories  image
The 7” Touchscreen Monitor for Raspberry Pi gives users the ability to create all-in-one, integrated projects such as tablets, infotainment systems and embedded projects. The 800 x 480 display connects via an adapter board which handles power and signal conversion. Only two connections to the Pi are required; power from the Pi’s GPIO port and a ribbon cable that connects to the DSI port present on all Raspberry Pi’s.  Touchscreen drivers with support for 10-finger touch and an on-screen keyboard will be integrated into the latest Raspbian OS for full functionality without the need for a physical keyboard or mouse.
*Note: Your NEW Rasp Pi 7.0 needs you to Add a Virtual Keyboard….
Raspberry Pi Sense HAT
Learn More  image
Technical Specification:
image  7” Touchscreen Display
image  Screen Dimensions: 194mm x 110mm x 20mm (including standoffs)
image  Viewable screen size: 155mm x 86mm
image  Screen Resolution 800 x 480 pixels
image  10 finger capacitive touch
image  Connects to the Raspberry Pi board using a ribbon cable connected to the DSI port
image  Adapter board is used to power the display and convert the parallel signals from the display to the serial (DSI) port on the Raspberry Pi
image  Will require the latest version of Raspbian OS to operate correctly
Features and Benefits
image  Turn your Raspberry Pi into a touch screen tablet, infotainment system, or standalone device.
image  Truly Interactive - the latest software drivers will support a virtual ‘on screen’ keyboard, so there is no need to plug in a keyboard and mouse.
image  Make your own ‘Internet of Things’ (IoT) devices including a visual display. Simply connect your Raspberry Pi, develop a Python script to interact with the display, and you’re ready to create your own home automation devices with touch screen capability.
image  A range of educational software and programs available on the Raspberry Pi will be touch enabled, making learning and programming easier on the Raspberry Pi.
Kit Contents
image  Adapter Board
image  DSI Ribbon cable
image  4 x stand-offs and screws (used to mount the adapter board and Raspberry Pi board to the back of the display
image  4 x jumper wires (used to connect the power from the Adapter Board and the GPIO pins on the Pi so the 2Amp power is shared across both units)
NOTE: THE RASPBERRY PI AND POWER SUPPLY ARE NOT INCLUDED IN THIS KIT AND ARE SOLD SEPARATELY.
Compatible With:
Raspberry Pi 3 Model B
Raspberry Pi 2 Model B
Raspberry Pi Model B+
Raspberry Pi Model A+
The display will technically work with the Model A and Model B boards (connecting it to the DSI port on the Pi board), however the mounting holes on the back of the display will only line up with the newer board design (A+, B+, Pi 2 and Pi 3).
How to Install the Matchbox-Keyboard for your Pi
1. Connect a physical keyboard to the Raspberry Pi (or SSH into it if that’s your thing.)
2. Connect to the internet via WiFi or Ethernet.
3. Open the terminal.
4. Type sudo apt-get install matchbox-keyboard
5. Let the program download & install (takes 30s-1min depending on your connection.)
6. Exit the terminal & reboot your Pi.
7. The keyboard can be found by clicking the Menu -> Accessories -> Keyboard.
Operating System Support
In order to be sure you’re running the latest version of Raspbian, connect your Raspberry Pi to the Internet and then open LX Terminal.  Type ‘sudo apt-get update’ to download the latest version of the OS.  Once that’s complete, type ‘sudo apt-get upgrade’ to apply the download to your Raspberry Pi.  That way you’ll have all of the latest drivers and software needed to support the touch screen display.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
  • pi_guide
  • raspberry
  • pi
  • pi_display
  • raspberry_pi
  • matchbox_keyboard
  • display
  • touchscreen
  • 7”
  • guide
  • installation
  • 7_inches
    shabaz over 9 years ago in reply to idometeor +3
    Jason Does Meteor wrote: As mentioned, I tried that. Actually you didn't, you stated: I have tried everything and I cannot get the display to rotate in Raspbian. I have written many X configuration files…
  • softweyr
    softweyr over 11 years ago in reply to ejohnfel +2
    Yeah, this is not a bad price for a 7" display, plus you get the touchscreen, integrated keyboard, etc. And tomorrow is my birthday!
  • bwelsby
    bwelsby over 11 years ago in reply to phantomski +2
    The reduced screen size is because Overscan settings are enabled. you can either comment out the settings in /boot/config.txt or just run raspi-config and select the advanced options then Overscan , Disable…
  • gadget.iom
    gadget.iom over 9 years ago in reply to mor3gan
    Hi mor3gan
    What model of Raspberry Pi are you using, and what operating system and version are you using?
  • mor3gan
    mor3gan over 9 years ago
    Just installed 7" touch screen everything came up fine. But. Always a "but". The touch is not working. Have a cursor but no movement.
    shabaz over 9 years ago in reply to CasaDelGato
    Hi John,
    Two of the wires are spare, you can discard them. See the instructions here
    Raspberry Pi 7” Capacitive Touch Display: Assembly and Enclosure
    and scroll to the section "Assembling the LCD Panel Interface Board and Pi".
  • CasaDelGato
    CasaDelGato over 9 years ago
    Missing connections in instructions???
    The instructions above only show using 2 of the wires to connect the power from the display to the Pi.
    There are 2 more wires, Which pins are used to connect the touchscreen?
  • oakguy
    oakguy over 9 years ago in reply to bwelsby
    Brian,
    I will add this command as well!
    Guy
  • oakguy
    Brain,
    I am runningPixel and that command does change the default from 30 minutes to indefinite and which kept the display up longer.  It would blank and then just moving a mouse would turn it back on.  However, after a period of time, it does go unresponsive with Pixel requiring pulling the power cord.  Perhaps an earlier copy of Raspbian would work better.  This screen and the Smartpi touch stand make a great weather station!
    Thanks!
  • bwelsby
    bwelsby over 9 years ago in reply to oakguy
    For GUI X windows mode try editing /etc/lightdm/lightdm.conf   find the  [SeatDefaults] section and add this line, then save and reboot:
    xserver-command=X -s 0 dpms
    Let me know if this works, I know they have added a new theme (PIXEL) but I am not sure if they have made any changes to the display manager which would prevent this from working.
    Brian
  • bwelsby
    Guy Wenzel wrote:
    Anyone have a tip on how to permanently disable the screen saver on CLI and Windows x mode? Raspbian Jesse?
    thanks
    I am not running GUI at the moment so can't confirm what works there, but for CLI mode adding   consoleblank=0  to the string in /boot/cmdline.txt works for me.
    Brian
  • oakguy
    thanks
  • kenbutt
    kenbutt over 10 years ago
    The problem with the display is the software needs to be downloaded from rasberry pi site.
    I bought my unit with the preinstalled NOOBS , but it doesn't update properly.
    I downloaded the full NOOBS and put it on the SD card , and the screen works fine now.
    Why would the preinstalled version be so limited . It is meant to help a new user get started , not  make it more difficult
