RoadTests & Reviews
RoadTests & Reviews
Review Blogs External Measurement Device Setup used --R&S RTM3K Oscilloscope Road-Test Review
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: snidhi
  • Date Created: 23 Jul 2018 5:05 PM Date Created
  • Views 1198 views
snidhi
snidhi
23 Jul 2018
This is a list of the external devices that were used to perform experiments during the road-test of Rohde & Schwarz Oscilloscope Kit RTM3K-COM4
  • List of Instruments Used in the Road-test
    • Noise Generator Noisecom NC6110
    • Other Oscilloscopes used for verification of measurements
    • GND Isolator Power Supply
    • Rhode und Schwarz Signal Generator SML03
    • Tektronix CSA 803A
The Noisecom NC6110 contains a precision noise source that delivers repeatable, symmetrical white Gaussian noise across a frequency range of 100 Hz to 1.5 GHz. The NC6110 noise source is integrated with an amplifier, a 10 dB 1 dB/step attenuator, and power supply. The NC6110 has a 50 ohm output impedance.
Fig: NC6110 noise source
Fig: NC6110 Specifications
Fig: 8GHz LeCroy WaveMaster
Tektronix 2GHz MSO
Fig: Tektronix DPO 7354C
Fig: GND Isolator between different devices to prevent GND looping
Fig: Specifications
Fig: R&S Signal Generator up-to 3.3GHz
Tektronix CSA 803A
The Tektronix CSA 803A is a high resolution Communications Signal Analyzer accommodating up to four input channels through the dual-channel sampling heads. With the SD-24 TDR/Sampling Head, four channels of single-ended TDR or two channels of differential TDR are available as well. It can generate very fast pulses in few picoseconds range.
Fig: Tektronix CSA 803A
    DAB over 8 years ago +2
    Nice set of test gear to run the road test with. DAB
  • snidhi
    snidhi over 8 years ago in reply to DAB +2
    Thank you for your supportive words Cheers
  • snidhi
    Thank you for your supportive words image
    Cheers
