1. Summary
I have been using an Ikalogic Scanalogic 2 (SL2) since 2010 but was always keeping an eye on what the company is doing because I always liked the product. Now, Ikalogic's SE254 has just arrived as an element14 RoadTest kit: I will put old and new side by side on real signals from a couple of my own hardware projects, Diagno and Wattson, and we will see what 15 years of logic analyzer design actually buys you.
Verdict: The SE254 is a lot faster, but to my surprise I found out that with a reasonable amount of tinkering you can get the old kit up to date. It can't possibly match the speed of the newer technology but I can say it is holding its ground unexpectedly well. The biggest difference turned out not to be speed but trust: when the SL2 runs out of headroom it gives believable wrong answers, and the SE254 shows what is really on the wire.
2. What is in the boxes
I still have the simple white cardboard box from the old one so I can say exactly that the old SL2 came in a kit format and I was not the one who assembled it. As far as I can remember it cost around 50€ and while it did come with probes I bought some extra clips and soldered myself some extra probes to have longer wires.
The SL2's plain white box from ~2010: "SCANALOGIC 2 KIT"
The SE254 came to me assembled and ready with probes and a micro USB cable. It has a completely different shape and the box consists of several layers of FR4 replacing the blue translucent plastic enclosure. It has some rubber pegs to prevent it slipping around on the desk. The probes I got with the SE254 are quite large, I will probably end up making myself another set of these smaller clips, or, if it proves itself to be the better analyzer, it will get the probe set from my old SL2. Long story short, my kit matches the expected content: device, 5-lead hook probe and a 1 m micro-USB cable.
The nice new black box of the SE254
The packing list isn't very complicated and apart from some SL2 cards and ziploc bags, this is pretty much everything that was inside. Both were bubble wrapped and both are in mint condition.
Old and new: the SL2 in its blue translucent case (left) and the SE254 FR4 Sandwich (right) with their probes
3. Who am I and how I test
I am an electronics enthusiast who enjoys building stuff but is mostly out of time. I built and documented projects on Instructables so far but not long ago decided to move camp a bit. My bench for this review:
- Ikalogic SL2 from 2010 – test unit 1
- Ikalogic SE254 from 2025 – test unit 2
- Rigol DM858E bench DMM – continuity measurements, setup quick-checks
- Rigol DP832 power supply – powering the setups
- PCBite magnetic probe set – connectivity for the setups
4. Why compare old and new
Instead of doing an unboxing experience I intended to do something different: I have owned Ikalogic's SL2 since 2010 and the SE254 is from the same manufacturer both hardware and software wise, but 15 years apart. That makes it a real generational comparison, grounded in years of actual use rather than a spec sheet. The SL2 helped me so much throughout the years that I intend to use this review to extend my thanks towards the designers of this great little analyzer.
The spec sheets already tell us which one should be better so the question is what upgrading changes day to day for someone who already has old Ikalogic gear and real embedded projects to debug. Does it just mean the ability to catch faster edges? To set up more sophisticated triggering systems? Or just more room in the shape of a larger buffer?
5. Meet the two analyzers
The SL2 is a (discontinued) 4-channel, 20 MHz unit with 256K points of capture memory per channel and a fixed input threshold. The SE254 is Ikalogic's hobbyist-tier unit (released April/May 2025): 4 channels, 250 MHz sampling (4 ns), 256 Mb of capture memory and selectable logic levels of 1.8, 2.5, 3.3 or 5 V.
The two units do not share a software generation. The SL2 runs on legacy ScanaStudio v2.3 (build 2.305.013 on my PC) and the latest ScanaStudio no longer supports it. My new SE254 runs on ScanaStudio 6.0.29 (build of 2026-10-28). Anyone dusting off an old Ikalogic unit will hit this software “problem” but it is not a big deal since they have been taking good care to always have their legacy installers available. Instead of having one of them installed, I will now have two.
6. The Lab Rats: Diagno, Wattson, and a Fistful of Breadboard Circuits
6.1 - Lab Rat 1: Diagno is a battery-powered, RP2040-based handheld with a color TFT and four reconfigurable test-needle probes. I built it to debug my Ben Eater inspired 8-bit computer. Its firmware is organized as self-contained feature modules; the one used here is the Logic Shifter, a generic Data/Clock/Latch/OE shift-then-latch driver built for the SN74HC595. It also generates PWM, servo, NeoPixel, UART and SPI signals, which gives the analyzers a wide spread of real signals from one handheld.
Diagno, the first lab rat, held in the PCBite stands with both analyzers hooked up.
6.2 - Lab Rat 2: Wattson is a breadboard-mount power supply, currently a breadboarded prototype on an ESP32-C3 Super Mini (concept page: https://www.grgelectric.com/wattson.html). It puts three very different digital signals on the bench at once: a 100 kHz I2C bus (SDA GPIO8, SCL GPIO9) with an INA3221 current/voltage monitor (0x40) and a PCF8575 I/O expander (0x20); a 20 MHz SPI link (SCK GPIO4, MOSI GPIO6, DC GPIO21) to an ST7789 TFT; and two 20 kHz, 10-bit PWM outputs (GPIO10, GPIO20) adjustable from a web page on the prototype's own WiFi access point.
Wattson, the second lab rat, breadboard prototype
6.3 - Lab Rat 3: A breadboard circuit with a string of SN74HC595 shift registers driving LEDs. This setup is intended to generate real feedback (like LEDs lighting up or patterns moving) of SPI and serial signals generated by Diagno. The four yellow jumper cables are Diagno's stabbing points, routed out for convenience.
HC595 breadboard setup, the third lab rat. Each probe header carries two Dupont leads, one going to each analyzer.
7. The Results
7.1 - The first captures
Before starting the real test plan I did a very first run, just to see both analyzers working on the same signal. Diagno’s Shifter feature was sending a 16-bit pattern into the SN74HC595 string on the breadboard and the LEDs were blinking as the pattern went through. Both analyzers were hooked to the same PCBite probe points: CH1 on the data line, CH2 on the shift clock and CH3 on the latch, with CH4 left idle. Both were set to trigger on the rising edge of CH3 (the latch) with about 10% pre-trigger.
To compare like with like I set both analyzers to the same sample rate, 2.5 MS/s (400 ns per sample). With that setting the SE254 captured 1 MSa (400 ms) and the SL2 captured 261,888 samples (104.755 ms).
Diagno driving the HC595 string through its needles during the first capture, LED bar graphs lit, analyzers sniffing
ScanaStudio 6.0.29 with SE254 at 2.5 MS/s (400 ns) and ScanaStudio 2.305.013 with SL2 at 2.5 MHz (400 ns), each with around 10% pre-trigger and rising edge trigger on CH3
Side by side the two captures are effectively identical.
• Same structure on both: one long first clock pulse (of about 70 µs), then 15 short clock pulses about 6 µs apart, with a longer pause (about 15 µs between rising edges) after the first eight. The latch pulse on CH3 is about 5.5 µs.
• Capture length at the same sample rate: 400 ms on the SE254 against 104.755 ms on the SL2.
• Clock pulse width reads about 2.6 µs on the SE254 and about 3.0 µs on the SL2, one sample of difference at this rate.
• The SE254 shows the threshold on every channel (Th 3.3 V) and marks the trigger point with a T. The SL2 shows no threshold because it is fixed, and the trigger marker has to be switched on.
• The long first clock pulse and the longer pause after the first eight clocks are Diagno’s doing, not an analyzer artefact, because both analyzers show them. Diagno times the shifter output in software, and its display refresh loop is called at regular intervals. When the refresh kicks in, the software-timed pulses lag and get stretched. The LEDs show nothing of this, but the capture shows exactly where the stalls are.
• The data line (CH1) changes right at the rising edge of the clock (CH2), within about one sample. At 2.5 MS/s neither analyzer can say which comes first.
7.2 - Baseline and Rig Check
Setup: Diagno PWM output at 1 kHz on CH4 (no trigger, 4 ms window), Diagno's own reading compared with both analyzers. The frequency was gradually stepped up: 10 kHz, 50 kHz, 250 kHz, 2.5 MHz and 9.999 MHz.
• This particular experiment also made Diagno better. Diagno’s PWM feature was capped at 10 kHz in the beginning, so I raised the limit to be able to test further. The 50 kHz, 250 kHz, 2.5 MHz and 9.999 MHz captures only exist because of this review.
• At 9.999 MHz the SL2 starts to have problems, as expected. Sampling at 20 MHz, it gets only about two samples per period. Its status bar reads F = 10.000000 MHz, TH = 50 ns, TL = 50 ns and D = 50.00%, so it truncates the measurement to a clean 10 MHz at a perfect 50% duty. At lower duty cycle (10%) the sampling begins to miss pulses.
• The SE254 keeps up. At 4 ns per sample it shows a period of about 104 ns (about 9.6 MHz), with the high about 56 ns and the low about 48 ns, which is a duty of about 54%. The SE254 is right - the RP2040 PWM divides its 125 MHz clock into whole counts. 9.999 MHz needs 12.5 counts, which becomes 13 counts per period: 125 MHz / 13 = 9.615 MHz, with the output high for 7 counts (56 ns) and low for 6 (48 ns). So the 9.999 MHz I asked for is really about 9.61 MHz, and the SE254 shows it correctly while the SL2 reports a number that is too good.
• Sweet feature: the SE254 shows the sample points. Zoom in far enough and it draws every sample as a dot, so you can count roughly 14 samples in each high and 12 in each low at 9.6 MHz. The SL2 only draws the line.
• 1 kHz was not exactly 1 kHz. Both analyzers measured a period of about 0.98 ms (about 1.017 kHz), which points to the same divider rounding at the low end.
Diagno PWM frequency |
Samples / Period SL2 / SE254 |
SL2 Measurement Period [us] |
SE254 Measurement Period [us] |
Verdict |
| 1 kHz | 20000 / 250000 | 980 | 980 | Agree that it is not 1 kHz and they are both right! |
| 10 kHz | 2000 / 25000 | 100 | 100 | Agree |
| 50 kHz | 400 / 5000 | 20 | 20 | Agree |
| 250 kHz | 80 / 1000 | 2 | 2 | Agree |
| 2.5 MHz | 8 / 100 | 0.4 | 0.4 | Agree |
| 9.999 MHz | ~2 / ~26 | 0.1 | 0.104 |
SL2 wrong SE254 right |
Input frequency, samples per period and the measurements of the two analyzers. They mostly agree!
| {gallery:width=700,height=530}PWM Measurements |
Pulses are getting missed by the SL2, which is expected because of the maximum sampling frequency |
PWM Measurements taken with the two analyzers
7.3 - Wattson I2C
Setup: 100 kHz I2C between the ESP32-C3 and the INA3221 (0x40) and PCF8575 (0x20). Both analyzers on the same points: CH1 on SDA, CH2 on SCL, CH3 on the INA3221 WARNING line and CH4 on one of the PWM outputs. The SE254 ran at 250 MS/s with 1 MSa (4 ms) at the 3.3 V preset. The SL2 ran at 20 MHz, first with 248,000 samples (12.4 ms), and for the decode capture with 79,360 samples (3.968 ms), so both windows were about 4 ms.
First capture, trigger on WARNING. Both analyzers armed on the rising edge of CH3. The SE254 can do more here: it holds two triggers at once, A (the edge on CH3 which I was using) and B (an I2C protocol trigger), combined with a trigger sequence setting, here I selected "A or B". The SL2 offers edge and level triggers only. Both caught the edge with pre-trigger data, and both measured the PWM on CH4 identically: 20 kHz, 28.7 µs high and 21.3 µs low (the SL2 reports D = 57.40%).
Rising edge trigger on WARNING (CH3): SE254 at 250 MS/s (left) and SL2 at 20 MHz (right), PWM on CH4 measured the same on both
Second capture, I2C decode. Trigger on the falling edge of SDA, which in practice catches the I2C start condition. SL2 does not offer I2C triggering and I wanted similar settings, hence the trigger condition. The firmware reads an INA3221 register: write to 0x40 with the register pointer 0x02 (channel 1 bus voltage), a repeated start, then a two-byte read from 0x40 that returns 0x00 0x00. Both analyzers measured SCL to be around 100 kHz (SE254: 99.8 kHz; SL2: 100.000000 kHz, TL 5.25 µs, TH 4.75 µs).
The SE254 decoded the whole transaction correctly in every capture while the SL2 did not. Over repeated captures of the same transaction it is right some of the time, but sometimes it decodes the first write badly and sometimes the read after the repeated start. In the capture shown here it is the read: the SL2 decoded the address as "WR 0x20" with a NACK and left a stray bit before the stop. The bits are the same, just shifted by one clock: the decoder placed the repeated start one clock too early, and everything after it slid along. 0x20 is a real address on this bus (the PCF8575), so this is the worst kind of decoder error: it doesn't look like garbage, it looks like the firmware is talking to the wrong chip. Because it changes from capture to capture, a single SL2 capture of an I2C bus can't be trusted on its own.
INA3221 register read decoded by the SE254 (left, correct) and the SL2 (right, one bit off after the repeated start; in other captures the first write goes wrong instead)
The two decoders present things differently. The SE254 spells it out ("Write to 0x40 – R/W = 0", "DATA = 0x02") and marks the stop with a P; at this zoom level the ACKs show only as small boxes. The SL2 is terser (WR 0x40, 0x2) but labels every ACK and NACK (A, N) and the restart (S).
7.4 - Wattson SPI at 20 MHz
Setup: Wattson redraws part of its ST7789 TFT over SPI with a 20 MHz clock. Both analyzers on the same points: CH1 on the clock, CH2 on DC, CH3 on CS and CH4 on the data line (labelled SDA on the display, it is MOSI). The SE254 ran at 250 MS/s with 1 MSa (4 ms), the SL2 at 20 MHz with 79,360 samples (3.968 ms). The SE254 triggered on DC rising; the SL2 on CS, which stays low.
The SL2 sampling at 20 MHz. The SL2 takes one sample every 50 ns, and Wattson's 20 MHz SPI clock completes a full cycle, high and low, in exactly that time. Each sample can see the clock high or low, but never both in the same cycle, so almost every transition between samples is lost. What is left is not a slowed-down clock but a different signal: a handful of wide, irregular pulses that are several microseconds long. The data line suffers the same way: bits that last 50 ns are either caught once or not at all, so the bursts on MOSI look shuffled and incomplete.
The result is gibberish on both levels. As a waveform it looks plausible, but it has nothing to do with what is on the wire. You couldn't count clocks or read a bit from it. The decoder fares no better: with no reliable clock edges to sample on, it reports a single "0x0" across the entire window instead of the CASET, RASET and RAMWR sequence. Only the slow DC line comes through correctly, with the same ~2.2 µs highs the SE254 shows. That is the point: the SL2 isn't malfunctioning. A 20 MHz bus is simply beyond what it can see.
The SE254 sampling at 250 MS/s. At 4 ns per sample, every period of the 20 MHz clock gets 12 to 13 samples, so every edge is there. Both the waveform and the decoder agree: CASET (0x2A) with columns 0x0053 to 0x0061, RASET (0x2B) with the same rows, then RAMWR (0x2C) and the pixel data, a 15 × 15 pixel partial redraw. Each byte takes about 0.4 µs, eight clocks at 20 MHz, as it should.
20 MHz SPI: SE254 at 250 MS/s (left) decodes every byte; SL2 at 20 MS/s (right) loses the edges and decodes gibberish
7.5 - Wattson PWM
Setup: Two PWM outputs at 20 kHz with 10-bit resolution, so one duty step is about 49 ns. At 50 ns per sample the SL2 sees roughly one sample per PWM step. The SE254 at 250 MHz (4 ns) sees about 12 samples per step.
At a middle duty setting both analyzers agree exactly: 20 kHz, 28.7 µs high and 21.3 µs low (see the WARNING capture in 7.3).
7.6 - Teaching an Old Analyzer a New Trick
Setup: Diagno's NeoPixel feature drives a frame of 8 LEDs, with the data line on CH3. Both analyzers trigger on a logic change on CH3. The SE254 ran at 125 MS/s with 2 MSa (16 ms), the SL2 at 20 MHz with 261,888 samples (13.09 ms).
NeoPixel frame, 8 LEDs: the SE254 at 125 MS/s (left) decodes every color; the SL2 at 20 MHz (right) shows the same frame as raw bits
Out of the box this one isn't close. The SE254's RGB LED decoder labels the whole frame as a RESET followed by LED 1 to LED 8, each with its color: #646464, #FFFFFF, #FFFF00, #FF00FF, #00FFFF, #0000FF, #00FF00 and #FF0000. The decoder has plenty of settings (chipset, color order, bit timing and tolerance), which turned out to matter.
The SL2 captures the signal just fine. At 20 MHz it gets 25 samples per 1.25 µs bit. What it lacks is a decoder. ScanaStudio 2.3 never had one for RGB LEDs, so reading 8 colors means decoding 192 bits by hand. That didn't sit well with me, so I went looking for a decoder for the old one.
- No decoder in the box. ScanaStudio 2.3 ships with 9 decoders: 1-Wire, CAN, I2C, I2S, LIN, Manchester, Parallel Bus, SPI and UART. Its "Find more decoders online" button ends on a "Page not found" page.
- The old scripts are still on GitHub. Ikalogic keeps the ScanaStudio 2 decoders at github.com/ikalogic/ScanaStudio-Decoders (last changed in 2018). Copying them into the decoders folder took the SL2 from 9 decoders to 33. A few of those the SE254 doesn't have, such as HC-SR04, character LCD, nRF24L01, SENT and NMEA 0183. Still no RGB LED.
- The new decoder doesn't fit the old software. Copying the SE254's RGB LED script into the old folder only produced a "[script error]".
- So I ported it. The SE254's decoder is open source (GPLv3), so I had A.I. rewrite its single-wire part for the ScanaStudio 2 API as rgb_led_ss23.js.
Result: Diagno sent a shorter frame of 4 LEDs: red, blue, green and white. The SL2 with the ported decoder read #FF0000, #0000FF, #00FF00 and #FFFFFF, followed by a RESET of 333.5 µs (Diagno's latch is 330 µs). The SE254 read exactly the same.
4 LEDs: the SE254 (left) and the SL2 with the ported decoder (right) read the same four colors
Timing matters. Diagno generates the signal with the RP2040's PIO. A 0 bit is 250 ns high and 1000 ns low; a 1 bit is 875 ns high and 375 ns low. The WS2812B defaults in both decoders (±150 ns tolerance) put Diagno's 0 bits right on the edge of the window. Neither decoded reliably until I entered the real timing on the SE254 and picked a ±400 ns tolerance on the SL2 port. That also put making Diagno's NeoPixel timing configurable at the top of its to-do list.
Out of the box, the SE254 still wins. An ordinary SL2 owner doesn't have this decoder. It took a dead link, a GitHub repository, a failed copy and a port to get here. But it shows what open decoders make possible: a 15-year-old analyzer learning a protocol its software never knew.
8 - Software Experience
Two applications, 15 years apart, and it shows, mostly in good ways.
- Two installs. The SL2 needs the legacy ScanaStudio v2.3 and the SE254 needs ScanaStudio 6. They live side by side without any trouble, and Ikalogic still offers the old installer, so keeping an old unit alive costs nothing but a second icon.
- Data fetch. In every test the SE254 fetched the capture to the PC much faster than the SL2. The SL2 may finish capturing quickly, but the transfer is noticeably slow. This is the difference you feel on every single capture.
- Trigger setup. The SL2 is simple: pick a channel, an edge or a level, and a pre-trigger position. ScanaStudio 6 adds a second trigger, protocol triggers (for example I2C) and a sequence setting that combines the two. The SL2 even has one thing the SE254 panel doesn't show: an after-trigger delay field.
- Seeing what you captured.
- ScanaStudio 6 shows the threshold on every channel and marks the trigger point automatically.
- When you zoom in, it draws every sample as a dot, which is great for judging how much the analyzer really knows about an edge.
- The SL2 draws only the line, and its trigger marker has to be switched on.
- Decoders.
- Both programs add a decoder in a few clicks.
- ScanaStudio 6's decoders have more settings and wordier labels ("Write to 0x40 – R/W = 0").
- The SL2's I2C decoder is terser but labels every ACK and NACK.
- Both have a packet view. ScanaStudio 6 also paints RGB LED colors into the cells, and so does my port on the SL2.
- Saving setups. Both can save a whole test setup and reopen it later. I kept one per test, which made repeating captures for this review painless.
- Extensibility. Decoders are plain JavaScript on both generations, but the APIs are not compatible: an SE254 decoder copied to ScanaStudio 2.3 only shows "[script error]". Porting one does work (see 7.6).
- Nags. ScanaStudio 6 shows two banners, one for a new app version and one for protocol updates. They take screen space in every capture, and the updates kept coming during the review.
9 - What I Could Not Test
- More than four channels. Decoders that need many signals (LPC, memory bus, parallel buses) can't be tried on either analyzer.
- The narrow-pulse limit. 7.5 only compares a middle duty setting. I didn't sweep Wattson's PWM down to its narrowest pulses.
- A continuous fast clock. My 20 MHz SPI came in short bursts, so I couldn't check Ikalogic's advice to use 125 MS/s for continuous clocks above 10 MHz.
- Signal generation. The SE254 has none, so the SL2's generator outputs had nothing to be compared against.
- Unit-to-unit variation. I have one of each.
- Other software and operating systems. The SL2 ran only on ScanaStudio v2.3, and both ran on Windows 11.
- Dense boards. All probing was on breadboards with hook probes and PCBite tips. Results on a dense PCB or with longer leads may differ.
10 - Conclusion
10.1 - What I liked
- It measures what is really there. At the 9.999 MHz setting the SE254 showed the real 9.615 MHz (125 MHz / 13) coming out of the RP2040, while the SL2 rounded it to a perfect 10.000000 MHz at 50.00% duty. A logic analyzer that hides an error like that is worse than one that shows it.
- Four times the capture window at the same sample rate. At 2.5 MS/s the SE254 kept 400 ms against the SL2's 104.755 ms.
- Decoders that save real work. The RGB LED decoder turned the NeoPixel frame into a RESET and labelled colors. On a stock SL2 the same frame is 24 bits per LED to decode by hand. ScanaStudio 6 lists 42 true decoders, all bundled and still being updated. Great work!
- Open decoders, even for the old unit. The SE254's decoders are open-source JavaScript on GitHub. That is what let me port its RGB LED decoder back to my 2010 SL2, which now decodes the same NeoPixel frame. There are possibilities for willing users of old hardware to keep their equipment and roll out useful updates for them.
- Faster data fetch. In every test so far the SE254 fetched the capture a lot faster than the SL2.
- It shows its work. The threshold is shown on every channel, and when zoomed in every sample is drawn as a dot, so you can see how much the analyzer actually knows about an edge.
- Selectable logic levels. Presets for 1.8, 2.5, 3.3 and 5 V, where the SL2's threshold is fixed.
- Reliable I2C decoding. SE254 I2C decode was right every time, where the SL2 occasionally shifted a byte by one bit and showed a real but wrong address.
10.2 - What I did not like
- Still four channels. Same count as my 2010 SL2. It rules out the decoders that need many signals (LPC, memory bus, parallel buses) and leaves no spare channel for an extra chip select or interrupt line.
- 250 MHz is not 250 MHz for everything. For continuous clocks above 10 MHz Ikalogic recommends 125 MHz, which halves the headline number on exactly the fast buses where you need it most. In my 20 MHz SPI test 250 MS/s worked fine, but the bursts were short; a continuous clock may behave differently.
- One logic level for all four channels. You cannot watch a 1.8 V and a 3.3 V signal at the same time.
- No signal generation. The SL2 could generate on two channels while capturing on the other two. The SE254 specs page lists no generator.
- Large hook probes. Fine on a breadboard, bulky on a dense board. I will end up making a smaller set, as I did for the SL2.
- Micro-USB on a 2025 design. USB-C would have been the obvious choice.
10.3 - Biggest problems encountered
Only minor ones.
- Two software installs. Anyone keeping an old Ikalogic unit runs the legacy ScanaStudio v2.3 next to ScanaStudio 6. Ikalogic still offers the legacy installers, so this is easy to solve.
- An update prompt mid-review. ScanaStudio offered 6.0.32 (and later 6.0.33) while I was testing on 6.0.29. I postponed it to keep every capture on one version.
10.4 - Verdict
In section 4 I asked what upgrading actually changes day to day: faster edges, smarter triggers, or just a bigger buffer. The answer is all three, but none of them turned out to be the main point.
The edges are the obvious win. Up to 2.5 MHz both analyzers agreed on every PWM measurement. Past that the SL2 runs out of samples, while the SE254 kept going and showed the real 9.615 MHz the RP2040 was producing. The buffer is real too: four times the capture window at the same sample rate. The triggers are a genuine step up, with two triggers combined and protocol triggering where the SL2 only has edge and level. On Wattson's 20 MHz SPI bus the gap is total: the SE254 decoded every command and pixel byte, while the SL2 lost almost every edge and its decoder returned gibberish.
What surprised me is that the biggest difference is trust. When the SL2 runs out of headroom, it doesn't show you a mess. It shows you a believable answer: a perfect 10.000000 MHz at 50.00% duty that never existed, or an I2C write to 0x20 (a real chip on the same bus) that never happened. A tool that is clearly wrong costs you a minute. A tool that is wrong but believable can cost you an evening chasing a bug in the wrong place. In every capture so far the SE254 showed what was really on the wire, down to the individual sample points. This doesn't make the SL2 obsolete, though. On slow buses, PWM and shift registers it matched the SE254 number for number. And because Ikalogic's decoders are open JavaScript, I ported a brand-new decoder onto a 15-year-old analyzer in an afternoon, with some A.I. help. If your work stays in the low-MHz range, an old Ikalogic unit is still a perfectly good tool.
If you debug anything fast, or anything where a convincing wrong answer is expensive, the SE254 is worth the upgrade. At 95 € it's an easy decision.
10.5 - Scores
The element14 form asks for six ratings from 1 to 5.
- Product performed to expectations: 5/5. It beat the SL2 on everything I measured. It showed the real 9.615 MHz that the SL2 rounded to 10 MHz, decoded I2C correctly in every capture where the SL2 occasionally slipped a bit, and decoded 20 MHz SPI byte for byte where the SL2 saw only gibberish.
- Specifications were sufficient to design with: 4/5. The specs page covers sample rate, bandwidth, memory, logic levels and input impedance, and even states the 125 MHz rule. It does not say what memory is used or whether there is signal generation.
- Demo software was of good quality: 4/5. ScanaStudio 6 fetches quickly, its decoders were right every time and have plenty of settings, and the two-trigger setup with protocol triggers is a real step up. It loses a point for the update banners that take screen space in every capture and kept coming during the review.
- Product was easy to use: 4/5. Logic-level presets and the threshold shown on every channel make setup clear. The large hook probes and one shared logic level for all four channels hold it back.
- Support materials were available: 4/5. Specs, the protocol list and even legacy installers for old units are on Ikalogic's site, and the decoders are open source on GitHub and actively maintained. That is what let me port one back to my 2010 SL2.
- The price to performance ratio was good: 5/5. At 95 € on Ikalogic's site (about $112 to $165 at distributors) you get 250 MS/s, 256 Mb of memory, 42 decoders and decoding you can trust. My SL2 cost about 50 € in 2010 for 20 MHz and 256K points.
11. Thanks and Links
Thanks to element14 for the RoadTest opportunity and to Ikalogic for their budget SE254. All the projects used here are mine.
- YouTube: youtube.com/@grgelectric
- Website: grgelectric.com
- Wattson project page: grgelectric.com/wattson.html
- Instructables: instructables.com/member/pityukecske
- Diagno Show & Tell: Diagno: the four-probe handheld that measures, generates and sniffs almost anything
- Ikalogic SE254 specifications: ikalogic.com/logic-analyzers/se254/specs
