RoadTests & Reviews
RoadTests & Reviews
Review Blogs TI SWIFT™︎ Power Module EVM Review: Part 2 Test Setup Description
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: snidhi
  • Date Created: 1 Apr 2018 10:38 PM Date Created
  • Views 805 views
  • test
  • wire & cable
  • setup
  • analog devices
snidhi
snidhi
1 Apr 2018
Part 2 : A quick overview of the devices used in the setup. And a short summary of the test setup
  1. Devices used in the setup
Set of Digital Multimeters
2 sets of Power Supplies
Hakko Soldering Station
RIGOL Oscilloscope upgraded to 500MHz Bandwidth
  1. Home-made cables and test boards for the Setup: I made some special cables to do 1x measurements with the oscilloscope.
Special Cables
High Wattage Resistors for large current measurements
All the current measurements were done using the 10 milli-ohm precise shunt resistor. It was used in series with other high wattage resistor load network.
TI SWIFTTm Power Module EVM Review: Part 3 Analog tests of the Power Module
TI SWIFTTmPower Module EVM Review: Part 4 Dynamically adjust the output voltage using external DAC
Go Back To: Road Test Review of TPSM84A21 Power Module
