RoadTests & Reviews
RoadTests & Reviews
Review Blogs TMC2300-IOT-REF - Remote controlled Stepper Motor - A closer look
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: Workshopshed
  • Date Created: 10 Feb 2021 8:43 PM Date Created
  • Views 1697 views
  • Comments 6 comments
Workshopshed
Workshopshed
10 Feb 2021
Following my problem trying to get the motor to run, I thought I'd check the board with a microscope to see if there were any issues. It all looks good an there are no obvious shorts, melted components or burns.
Power
USB
TMC2300
ESP32
  • Gough Lui
    Gough Lui over 5 years ago in reply to Jan Cumps +3
    I would too personally, or a mishap damaging a component, but the reason I bought it up was because that resistor is R23 which pulls down the EN line on the TMC2300x which trinamic_lisa suggested was worth…
    Jan Cumps over 5 years ago in reply to Gough Lui +3
    Gough Lui wrote: I.. Nice to see KiCad getting some love . True <3
    Jan Cumps over 5 years ago +2
    Andy, I read that your power circuit gets hot, no matter what's connected as source or load. If it gets hot even when there's no motor attached, that's a real sign that things are wrong. These are all…
  • Workshopshed
    Workshopshed over 5 years ago in reply to Jan Cumps
    Jan, the problem started when I tried a sketch that pulsed the step pin on IO21. There was smoke from around the power section before I disconnected it.
    Gough Lui  wrote:
    I..Nice to see KiCad getting some love image.
    True <3
  • Gough Lui
    I would too personally, or a mishap damaging a component, but the reason I bought it up was because that resistor is R23 which pulls down the EN line on the TMC2300x which trinamic_lisa suggested was worth checking. If that line floats, it could result in unexpected current draw. There is always the potential for a marginal connection becoming broken due to thermal cycle stress or mechanical bending stresses etc. A long shot, I know ...
    At least, that's what opening the KiCad schematics tells me. Nice to see KiCad getting some love image.
    - Gough
    Andy's board worked in the beginning. That's why I'd suspect a defect component.
    He mentioned "too much current from the USB". I'd doubt that because the USB is not powering the motor.
  • Gough Lui
    Hmm ... one connection on the SMD resistor just north of the TMC2300x has a suspicious blobby solder joint. I doubt it's the cause of the issue although that would (in my experience) increase the likelihood of it being a faulty joint, but it looks somehow inconsistent with the quality of the other solder joints.
    - Gough
