RoadTests & Reviews
RoadTests & Reviews
Review Blogs Unboxing Würth Elektronik WE-CBF Ferrites Kit
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: misaz
  • Date Created: 12 Apr 2023 2:19 PM Date Created
  • Views 1812 views
  • Likes 11 likes
  • emc
  • wurth electronik
  • emi
  • wuerth_elektronik
  • würth
  • würth elektronik
  • ferrite
  • passives
  • wurth_elektronik
  • design kit
misaz
misaz
12 Apr 2023
Hello everyone.
Last week I was randomly selected as a winner of giveaway as part of quiz in Ferrites Essential module sponsored by Würth Elektronik. Today I received the reward. Let’s look at it.
Code of the Kit which I received is 742 791. More details about kit you can find at it’s WE page: Design Kit WE-CBF/WE-PBF/WE-CMS/WE-SUKW Ferrites
You can buy it for example at Farnell/Newark here: Buy Now
Unboxing
Kit come in branded paper box.
Inside the box is nested plastic box holding the main kit.
You can notice tweezer label on the right side of the box and tweezer above it. It is simple plastic tweezer. Tweezer have 93302 written on ait and most probably it is this one: http://www.waterun.com.cn/En/Products/show?id=567
It is plastic so it is impossible to use it when hand soldering components form the kit but for picking component out of the box it is suitable. Generally, it is good accessory bundled with electronic component kit and I like it.
Now let’s look to the kit inside:
The main contents of the kit (ferrites) are stored in plastic test tubes. There are 34 of 36 slots filled. On the bottom there is holder and test tubes remain fixed even if you swap the kit upside down. Every test tube has label describing its content.
Kit contents
Kit has inlay letter describing the parts. It is also available in PDF for download at WE page.
According to website kit should contain 690 parts of 34 value and 10 case sizes. When I was waiting for kit, I was thinking about parts quantity because 690 / 34 = ~20,29 and this is fractional number. So, there are some parts in larger quantities than some other. By the way I counted 705 parts in the kit instead of 690. Now I know what the WE slogan “More than you expect” which is written on the boxes means. Blush Most parts are in standard 1206, 1210, 1806 and 1812 packages. Last row contains parts in different (larger and longer) packages. There is also confusion because kit page on WE website do not link all parts which are in kit. Kit has 34 parts types and only 30 of them is linked on website. Website information also have no information about quantities for each part in kit. For these reasons I decided to summarize kit in the table below.
The WE parts best fit designs with Maxim Integrated chips because their parts follow the same naming convention – just a random numbers. All part starts with number 742 which most probably indicates ferrites. Most components have second part set to 792 but there are also few parts from 793 and 751 series. The last numbers most probably have some meaning, but I did not find any relation between the number and value. Components have broad range of values. Maximum impedances are in range between 50 and 1300 ohms at frequency about 1 GHz. Mentioned are also impedances at 100 MHz. Parts in the kit have 100 MHz Impedances in range 30 to 1000 ohms so you have very broad options to select. Permitted currents range from 200 mA to 6A. WE provides fantastic documentation for each part including CAD files and simulation data as well as detailed datasheet which shows the most details of part. Similarly at the kit page there is PDF document containing summarized Impedance characteristics plots for all parts in the kit.
My last note is about status of parts. Kit was designed in 2010 and two parts from the kit was marked as NRND in meantime but generally kit is still very usable and valuable.
Part Number
Case
Z @ 100 MHz (Ohm)
DCR (Ohm)
I_R (mA)
Quantity in box
742 792 1
1206
32
0,2
500
30
742 792 11
1206
90
0,3
300
30
742 792 122
1206
220
0,3
300
30
742 792 13
1206
600
0,3
200
30
742 792 133
1206
600
0,3
500
30
742 792 14
1206
1000
0,45
200
30
742 792 112
1206
31
0,04
3000
30
742 792 15
1206
80
0,03
3000
30
742 792 121
1206
300
0,06
3000
30
742 792 18
1206
600
0,1
2000
30
742 792 141
1206
1000
0,3
1000
30
742 792 30
1210
32
0,3
400
30
742 792 3
1210
90
0,3
400
30
742 792 310
1210
30
0,05
3000
30
742 792 311
1210
52
0,05
3000
30
742 792 312
1210
65
0,03
3000
30
742 792 4
1806
60
0,3
400
15
742 792 42
1806
150
0,5
200
15
742 792 410
1806
60
0,01
6000
15
742 792 411
1806
80
0,04
3000
15
742 792 45
1806
110
0,035
4000
15
742 792 44
1806
850
0,1
1500
15
742 792 5
1812
120
0,3
300
15
742 792 50
1812
70
0,3
300
15
742 792 510
1812
70
0,03
6000
15
742 792 511
1812
120
0,05
3000
15
742 792 515
1812
785
0,05
3000
15
742 792 52
1812
880
0,035
4000
15
742 793 0
4.0 x 3.0 x 2.55
42
0,006
6000
10
742 793 1
8.5 x 3.0 x 2.55
91
0,009
6000
10
742 793 2
7.8 x 4.75 x 3.0
85
0,009
6000
10
742 752 1
9.0 x 5.6 x 2.5
52
0,01
5000
5
742 751 1
8.0 x 5.0 x 4.6
416
0,01
5000
5
742 751 2
11.0 x 4.65 x 5.0
580
0,003
5000
5
While parts are in test tubes, they are placed in cut tape except large size components in last row which are in loose form.
The 1206 and 1210 parts are stored in 3 cut tapes with 10 units each, total 30 parts of each 1206 and 1010 value:
The larger 1806 and 1812 parts are stored in one bend tape with 15 pieces per value:
Remaining parts in last row has non-standard case size and are stored in loose form except the first one which is on the cut tape like in previous cases. The first three units from the row are 10 pcs each and the largest parts are 5 pcs each.
Summary
I have not tried the any part yet, but I currently work on one design in which I will use ferrite and plan to test some parts from this kit for filtering. After selected as a winner I also decided to experiment with ferrite used in boost DC/DC converter but currently I have no time to do some extensive tests of these components because I have lot of work with finishing university.
It is very nice kit. While information about kit is incomplete on the web, everything became clear after opening kit. Kit has nice structure, everything (paper box, plastic box, test tubes, letters) are WE branded and looks very nice. Kit contains lot of parts covering large range of values. There are some other ferrites kits in WE offer differing in size (this is large size kit, there is small size also) and type. All of them looks valuable but for people who use ferrites only rarely there are slightly expensive (but not overpriced) I think. For company it should be ok. If you are rich enough, you can even go WE ferrites rack: Alpha-Rack EMC: Ferrites which contains this kit and few other. Also note that this is not the only kit offered by WE. Instead they offer similar kits for almost tall other parts they offer, so you can find similar nice kits for example for LEDs, Inductors, connectors, and many other.
  • Würth Elektronik
    Würth Elektronik over 3 years ago +2
    Hi misaz great to hear that the kit found you well. Thank you for the nice write up and good luck with your tests. If you need any help we are happy to support you. Also for testing maybe our online…
    dougw over 3 years ago +1
    Nice write up of the kit.
  • scottiebabe
    scottiebabe over 3 years ago +1
    Congrats! Good luck on your studies. Enjoy your low quality (factor) inductors
  • Würth Elektronik
    Würth Elektronik over 3 years ago in reply to Würth Elektronik
    REDEXPERT (we-online.com)
  • Würth Elektronik
    Hi misaz
    Also for testing maybe our online simulation toll REDEXPERT will be of help.
    Nicola
    Würth Elektronik
  • scottiebabe
    Congrats! Good luck on your studies. Enjoy your low quality (factor) inductors Slight smile
