RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum TDK Lambda RoadTest List
  • Blogs
  • RoadTests
  • Reviews
  • Replies 25 replies
  • Subscribers 2746 subscribers
  • Views 4255 views
  • RoadTest
  • tdk
  • lambda
GardenState
GardenState over 16 years ago
Following is the list of TDK Lambda RoadTest event winners
To receive their RoadTest product all those listed should send their mailing address to me via Private Message (which can be accessed by clicking your user name to view your Profile. When you compose a message send it to my username, which is GardenState.)
TDK 2  LS25-3.3LS25-3.3
George Andor
Tom Davies
TDK 3 LS35-3.3LS35-3.3
Alun H
Frank Cassidy
TDK 5 LS75-3.3LS75-3.3
Xavier CHAZE
Cioba Cosmin
TDK 7 LS1505LS1505
David Jones
Anders Norstrand
TDK 8 LS25-5LS25-5
Gregory M. Brettell
kadir korkmaz
Mateusz Liszczyk
Laszio Andor
Harry Sokol
Joncas
TDK 10 LS505
Marcos Gomes
Dan Svanda
Ricou Cocquerez
Thomas Kunjummen
Glenn Berden
L K
Kok Yong Neo
TDK 12 LS10012LS10012
user554
danteo
Mario gagnon
TDK 13 LS15012LS15012
FIRAT KOCAK
Paul Kennedy
Carson Au
Carsten Doerwald
Mahmut Demir
Joshua Padman
Werner Blankenberg
Eche Ogah
Stefan Geissler
Diego Guerrero Rivero
TDK 15    LS35-12LS35-12
Ondrei Karas
TDK 16 LS5012LS5012
Phil Pemberton
TDK 17   LS7512LS7512
Amine Amri
Michael Winn
Norman Blackburn
TDK 18   LS10015LS10015
Keith Devine
TDK 19 LS15015LS15015
Florin Constantin
David Checkley
Murat YILDIZ
Karol Białek
Joy Mcjoy
Robin Bieber
TDK 20 LS25-15LS25-15
John Harrison
TDK 22  LS5015LS5015
Goran Sander
TDK 23 LS7515LS7515
Dmitry Pikulins
Dominik Paasch
TDK 24 LS10024LS10024
Evan Jones
TDK 25 LS15024LS15024
Bryon Burns
Davide Calusini
Alexander Schönberger
Karoly Pados
Graham Holloway
TDK 26  LS25-24LS25-24
James Hill
TDK 31   LS50036
Jaime Aranguren
Fausto Baldoni
Marcel Sladacek
TDK 37 LS-15048
Daniel Forbes
Christopher West
TDK 35  LS7536LS7536
Mike Wilkinson
TDK 38 LS25-48LS25-48
Dave Yamakuchi
TDK 41  LS7548LS7548
Christopher Singleton
Nicu Gavrila
  • gbrettell
    gbrettell over 15 years ago in reply to Nortski
    Excellent!  Glad to see the addition of the plastic cover ...
  • awinning
    awinning over 15 years ago in reply to R_Phoenix
    Sorry you missed out there. I think everyone who applied got one of the supplies. We have changed the way we run RoadTests, so we have your address when you enter. You can look up the test after the event and see who has been "approved". Even if you don't look at the list, I have your address, so you will receive the kit anyway
  • R_Phoenix
    R_Phoenix over 15 years ago
    WOW, I know it's too late but I never new I was selected to receive one of these. What type of notification is in place for the future?
    Hi all I have received the LS150-36.I have used it drive two motor h-driver and work fine whitout probleI have proposed at my boss to change toroidal trasformer and stabilizer whit this new power supply The only problem are the dimension Are too big,it's to hard accomodate two  LS150-36LS150-36 a little 1U case I thinks that is possible to reduce it
    Reagards
    e14 Contributor over 16 years ago in reply to e14 Contributor
    I received mine a little while ago an  LS75-12LS75-12 I haven't had chance to do anything with it yet though Probably going to be another couple of weeks still However my first impression is actually that it is quite large There seems to be a lot of open space inside and big blank areas on the PCB Indeed there are two fairly large capacitors marked on the PCB but not fitted I'm not sure if the same PCB is designed for multiple devices and this is the lower power version My target application is much more concerned about physical size than heat dissipation It needs to be compact but will be rarely running at full power output
    e14 Contributor over 16 years ago in reply to Nortski
    psysic? hows about printing the maximum depth the mounting screws can go and their size on the bottom lable, could save a lot of confusion and heartache. You know what engineers are like, the first thing to hit the bin is the instructions...:-)
  • firatkocak
    firatkocak over 16 years ago in reply to GardenState
    Hi Garden,
    Could you check the state of mine, please ?
    Firat
    e14 Contributor over 16 years ago in reply to GardenState
    OK, sorry to be a pest...I know it's free and all.  I just had something I was trying to do I thought was perfect for that very supply, right around the time it went on the "road test list"...and it _has_ been a couple of months now. I appreciate your help in getting this all sorted out.  I'll wait and we'll see...
  • GardenState
    GardenState over 16 years ago in reply to e14 Contributor
    Dave:
    Yes we are reading this and yes we have your mailing address. We are tracking the status of the TDK Lambda shipment and will reply with more info soon.
    GardenState
  • Nortski
    Nortski over 16 years ago in reply to e14 Contributor
    Hi David,
    Thank you for the comments.
    I am pleased to say that production started this month with a new terminal block which has a plastic cover.  See picture.
