RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Fundamentals with Multicomp Multimeter + Accessories Road Test MP730624 Bluetooth questions -
  • Blogs
  • RoadTests
  • Reviews
  • Replies 7 replies
  • Subscribers 2743 subscribers
  • Views 5106 views
  • RoadTest
  • scasny
  • multicomppro
  • dmm
  • multicomp
robogary
robogary over 4 years ago
Page 4.1 - The instruction manual says to install the application software on your Android phone. Nothing else. Fantastic,I go the Galaxy store and try searching for Multimeter, MultiComp, MulticompPro, -- no matches found. What software package name goes for this DMM MP730624 ?
Page4.5 - The instruction book says in the software app to turn on Bluetooth & scan. Well............my phone has bluetooth enabled all the time. It connects to my car, bluetooth speakers, etc all the time. I went into settings, had all other Bluetooth devices either off and out of range, and the DMM was not detected by my phone. Yes, I did have the DMM BLE turned on by holding down the Hz/Duty/BLE button. Is the instruction saying the APP has to be running in order to connect bluetooth by phone ? very strange
Page 13 - manual states use only the bluetooth USB device (optional) supplied with with the product. OK, I can order a bluetooth adapter for my PC, but which one ? Does this DMM use bluetooth 4 , or BLE ? The instruction manual uses both terms interchangably.
Page 13.1 - The manual says Install multimeterBLE software. Where ? I googled every plausible name I could think of, but never found it. I did not find a Download page on the Newark site
Please advise, thanks for any help
  • robogary
    0 robogary over 4 years ago in reply to javagoza
    Installed software and connected to DMM. Thank you for excellent advice. My reputation is saved.
  • robogary
    0 robogary over 4 years ago in reply to Gough Lui
    Thank you, Yes, this is a really good report to review. and a very helpful reply.
  • robogary
    0 robogary over 4 years ago in reply to hlipka
    Perfect, thank you. I found the documentation as per your valuable reply, which has the needed details omitted from the Quick Start Guide.
  • hlipka
    0 hlipka over 4 years ago
    The page for the MP730624 too has a software download (under 'technical documents'), which has a ZIP with asn APK in it.
    Also, since this seems to be similar to the Owon 18B, you might be more lucky with their documentation. (Where it states that a phone with BLE 4.0 is required)
    • Vote Up +5 Vote Down
  • javagoza
    0 javagoza over 4 years ago in reply to Gough Lui
    I have tried to communicate from python using bleak and connecting from Windows 10 with the built-in Bluetooth of my Microsoft Surface Studio 2 without the need of another adapter. It works well and is a good option for logging and graphing measurements.
    bleak.readthedocs.io/.../index.html
  • javagoza
    +1 javagoza over 4 years ago
    Hi, I have the MP730026 and you can download the apk from the Farnell Store:
    MP730026 EU-UK
    uk.farnell.com/.../3107584
    Download, unzip
    And now you can install the apk via the ADB, Android Studio, or sending by mail to your phone or copying to the downloads folder.
    Hold Bluetooth button on the DMM until the Bluetooth icon blinks
    press on "No device"
    An scan, my DMM is call BDM
  • Gough Lui
    +1 Gough Lui over 4 years ago
    I reviewed this meter a while back in 2020 - you might want to take a look:
    /members-area/personalblogs/b/gough-lui-s-blog/posts/review-multicomp-pro-mp730026-3-75-digit-ble-digital-multimeter
    Specifically, the app should be called MultimeterBLE, but it seems to have been pulled off Google Play for some reason. You can try downloading it directly from OWON - https://www.owon.com.hk/supports_mobile_app The package name was com.owon.MultimeterBLE and it still seems to be available on the Apple App Store https://apps.apple.com/us/app/owon-multimeter-ble/id1049176636
    However, baldengineer did some reverse engineering of the protocol, so use with Python and a PC with a Bluetooth 4.0 LE capable adapter is possible (and preferred):
    /challenges-projects/element14-presents/workbenchwednesdays/b/blog/posts/mp730026-dmm-ble-tutorial-using-python
    - Gough
