RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Cleaning up table of contents and navigation in RoadTest Reviews
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 15 replies
  • Subscribers 2662 subscribers
  • Views 2533 views
  • contents
  • menu
  • navigation
cstanton
cstanton over 2 years ago
We've realised that there's some duplication with tables of contents, particularly when it comes to RoadTest Reviews, and with our new Project Articles ( Ho-Ho-Hold on a minute, is that a blog? A new way to submit your project! ).
Verint, as a platform, has a way of inserting 'tables of contents' like this:
But there are problems with its formatting and how it works. For RoadTest Reviews as an example, we have an automatic generation of a table of contents which can look like this:
This helps to separate the content from the contents list when listing the content on Google, sharing on social media, etc. So we use this method in RoadTest Reviews and Project Articles.
Because we have this, it means that it's a duplicate of the 'insert table of contents' and you can end up with a heading of "table of contents" in this new list, and it becomes a bit cumbersome and confusing, it doesn't make sense to have both.
So ultimately, we won't.
For Project Articles and RoadTest Reviews we're removing the ability to insert the table of contents from the menu.
Instead? Use headings, marked with the <hx> tags, where 'x' is a number. A lot of members already do this, but I realised we haven't actually pointed this out anywhere.
You can find heading formatting under the Format menu:
These menus should always be visible when using the Community from a laptop or desktop, maybe even a tablet. It may not always be visible when using a mobile device.
Thanks for reading!
    shabaz over 2 years ago +1
    Hi Christopher, Will this mean the text are is narrowed? Is there a way to regain the text area by (say) having the left-side ToC being collapsible automatically? This will be a big issue with especially…
  • Gough Lui
    Gough Lui over 2 years ago in reply to shabaz +1
    Yeah, I've also previously expressed my dislike of the sidebar ToC because it takes up space and mucks up printability of the article. I manually trudge though the inspector and delete the div when reading…
  • cstanton
    cstanton over 2 years ago in reply to Gough Lui +1
    Gough Lui said: I've also previously expressed my dislike of the sidebar ToC because it takes up space and mucks up printability of the article I've raised a support ticket about that, so it should be…
  • cstanton
    cstanton over 2 years ago in reply to gpolder
    gpolder said:
    The upper table of contents doesn't work any more.
    Same for all my other pre verint reviews.
    Thanks for the links.
    I have looked at the HTML markup on the links, and I can see why they no longer work.
    These links at some point used to link to another element on the same page. These have been lost and will no longer work.
    The best approach would now be to remove that table of contents that's inserted at the top, and make sure that the headings are properly sized (H1 to Hx) on the content to populate the new table of contents.
  • cstanton
    cstanton over 2 years ago in reply to shabaz
    shabaz said:
    Any chance we can have a few more styles added for inset types of messages?
    These are nice ideas, I like them! I do not know how easy/possible they are to implement, but I can ask.
  • gpolder
    gpolder over 2 years ago in reply to cstanton
    sure, did already for some, need to do more.
  • colporteur
    colporteur over 2 years ago in reply to cstanton
    was the word you meant to use compromised by Verint?
  • cstanton
    Thank you.
