RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Help me to setup the software to use the trimak motor
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 91 replies
  • Subscribers 2555 subscribers
  • Views 2289 views
  • RoadTest
  • problem
  • motor control
  • trimak
  • motor
manojroy123
manojroy123 2 months ago
I am trying to install TMCL-IDE for windows. I am getting this error. Please help me in solving it.
  • cstanton
    cstanton 1 month ago in reply to manneveru +3
    manneveru said: This is not right forum for this post This post is relating to a RoadTest and its consequent review, it's the correct place for it to be situated. You can turn off replies to the thread…
    Jan Cumps 1 month ago in reply to manojroy123 +2
    Manoj, it may help if you: use the correct name in the subject. Shows respect to the manufacturer that sponsored the board explain what step you are trying to complete in the user guide/documentation…
  • beacon_dave
    beacon_dave 2 months ago in reply to manojroy123 +1
    https://www.analog.com/media/en/technical-documentation/user-guides/how-to-start-linux-tmcl-ide.pdf
  • manojroy123
    manojroy123 1 month ago in reply to cstanton
    Ok, thanks. Let me check the solution you provided. I think it should solve most of the problem I am facing.
  • beacon_dave
    beacon_dave 1 month ago in reply to manojroy123
    Perhaps try the latest version ( 3.11.3 ) as the release notes show there were more bug fixes after the initial release for the TMC9660.
  • manojroy123
    After asking on chatgpt it says that you need to configure the motor from Wizard Pool in TMCL-IDE 4.x. But Wizard Pool is not showing any motor. Bellow is the pic of it.
    How to know what has caused the error of device not detection on Wizard Pool of the TMCL-IDE 4.x
  • beacon_dave
    May be relevant ?
       "I  found that most of my plugins were disabled.
       Once I enabled them again, I was able to use the wizard."
    https://ez.analog.com/motor-control-hardware-platforms2/f/q-a/599152/with-evaluation-board-tmc9660-3ph-evalv1-1-boot-setting-is-good-but-wizard-is-empty
  • manojroy123
    manojroy123 1 month ago in reply to beacon_dave
    I have updated firmware with latest version. Still showing same problem. How to enable plugins.
  • beacon_dave
    Perhaps refer to the user manual for guidance.
    I'd hazard a guess that they may of meant the 'Enable driver' checkbox
    Presumably you completed both the power on
    and the bootloader configuration settings
    steps successfully before attempting to launch the Wizard Pool ?
  • manojroy123
    Should the display LED on the software that is detecting voltage of the board be red for board to be detected.
  • manojroy123
    UBL Bootstrapping is not showing.
    Did you perform the step by step setup of https://www.analog.com/media/en/technical-documentation/user-guides/tmc9660-3ph-eval-kit-ug.pdf ?
    Getting Started
    • IO Supply Selection
    • Connecting the Peripherals
    • TMCL-IDE Quick Start
    • Turn on the power supply now.
  • manojroy123
    manojroy123 1 month ago in reply to Jan Cumps
    Yes. I am using a 12 volt 8 amp power supply.
