RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Most of the problem with the TMCL-IDE 4.7.2 is solved. i need help with respect to starting the motor
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 21 replies
  • Subscribers 2662 subscribers
  • Views 1223 views
  • problem
manojroy123
manojroy123 5 months ago
Most of the problem with the software and driver board are solved. I was even able to get fault LED on driver board OFF. I am not able to start the motor. Can someone Please guide me in starting the motor.
  • cstanton
    cstanton 5 months ago in reply to manojroy123 +3
    We're soon going to have a webinar with Tektronix on "Oscilloscopes 101" that you may want to join and ask your questions in if you're struggling to find resources online on how to use your oscilloscope…
    Jan Cumps 5 months ago in reply to manojroy123 +1
    When I'm participating in a road test, I usually set up a slack channel, and invite the fellow roadtesters via the e14 messaging functionality: I created a slack channel for the XXXXX roadtest Only…
  • cstanton
    cstanton 5 months ago in reply to Jan Cumps +1
    We have an element14 Community discord server that we can use for this, alternatively I can spin up a dedicated forum for it. I'd prefer it if these kinds of conversations where somewhere that the element14…
  • manojroy123
    0 manojroy123 5 months ago in reply to beacon_dave
    How to check UVW connection for any pulse for motor rotation. Can this diagnosis help.
  • beacon_dave
    0 beacon_dave 5 months ago in reply to manojroy123
    Depends if you mean UVW phases of the motor or UVW of the feedback hall sensor.
    Perhaps include a schematic and photograph of you RoadTest setup along with motor details.
    Perhaps also check the documentation for what the status code returned means
  • manojroy123
  • manojroy123
    How to check if trapezoidal wave is being generated or not.
    0 Jan Cumps 5 months ago in reply to manojroy123
    Do you have an oscilloscope?
  • beacon_dave
    Perhaps also check the motor configuration parameters against the specification of the motor in use.
    e.g. if the motor current is set too low then the motor may not run.
  • manojroy123
    0 manojroy123 5 months ago in reply to Jan Cumps
    Can't multimeter show any voltage jhum in voltage mode.
    Yes, but it will be hard to see if the signal is a trapezoidal wave.
  • manojroy123
    Yes
  • manojroy123
    Please tell me, how to measure it with oscillocope ?
