Ikalogic Now and Then - What 15 Years can do
View table of contents ...
RoadTest: RoadTest Open Call
Author: thegrgelectric
What other parts do you consider comparable to this product?: Saleae Logic Analyzer, ZeroCube Logic Analyzer
What were the biggest problems encountered?: No important problems , I am very familiar with Ikalogic products! Apart of minor nags, everything was easy to set up and control.
This is the short version. The full write-up, with every setup, measurement and screenshot, is in my blog post: Ikalogic Now and Then - What 15 Years can do.
The idea
I have used an Ikalogic ScanaLogic 2 (SL2) since 2010. The SE254 is the same company's 2025 hobbyist analyzer, so instead of an unboxing I put old and new side by side on real signals from my own projects: Diagno (an RP2040 handheld test tool), Wattson (an ESP32-C3 breadboard power supply prototype) and an SN74HC595 breadboard circuit. The question: what does upgrading actually change day to day?
Old and new: the SL2 (2010, left) and the SE254 (2025, right)
SL2 (2010) SE254 (2025)
Sample rate 20 MHz 250 MS/s
Memory 256K points per channel 256 Mb
Logic threshold Fixed 1.8 / 2.5 / 3.3 / 5 V presets
Software ScanaStudio v2.3 (legacy) ScanaStudio 6
Price About 50 € kit (2010) 95 €
Results at a glance
Test SL2 SE254
Shift register capture at 2.5 MS/s Correct, 104.755 ms window Correct, 400 ms window
PWM 1 kHz to 2.5 MHz Correct Correct
PWM at "9.999 MHz" Shows a perfect 10.000000 MHz, 50% (wrong) Shows the real 9.615 MHz (right)
I2C at 100 kHz Sometimes slips one bit and shows the wrong address Correct in every capture
SPI at 20 MHz Aliased, decodes gibberish Every byte decoded
NeoPixel (WS2812B) No decoder; with my port: correct Decoded out of the box
The highlights
It measures what is really there. I asked Diagno's RP2040 for 9.999 MHz. The RP2040 can only divide its 125 MHz clock into whole counts, so it actually puts out 125 / 13 = 9.615 MHz. The SE254 showed exactly that. The SL2, at two samples per period, reported a perfect 10.000000 MHz at 50.00% duty, a number that never existed.
I2C: a believable wrong answer. On Wattson's 100 kHz bus the SE254 decoded every INA3221 register read correctly. The SL2 sometimes placed the repeated start one clock too early, shifting everything by one bit, and decoded a write to 0x20, which happens to be the real address of another chip on the same bus.
image image
The same INA3221 read: SE254 (left, correct) and SL2 (right, one bit off after the repeated start)
SPI at 20 MHz: no contest. Wattson drives its ST7789 display at 20 MHz. At 250 MS/s the SE254 decoded CASET, RASET, RAMWR and the pixel data byte for byte. The SL2 samples once per clock period, so almost every edge is lost: the clock turns into a few wide, fake pulses and the decoder reports a single "0x0".
image image
20 MHz SPI: SE254 at 250 MS/s (left) decodes every byte; SL2 at 20 MS/s (right) loses the edges
Teaching an old analyzer a new trick. The SE254 decoded Diagno's NeoPixel frame out of the box; the SL2 had no decoder for it. Ikalogic's old ScanaStudio 2 scripts are still on GitHub (9 decoders became 33), and the SE254's RGB LED decoder is open source, so I had it ported to the old API with some A.I. help. My 2010 SL2 now reads the same four colors as the SE254.
image image
4 LEDs: the SE254 (left) and the SL2 with the ported decoder (right) read the same four colors
What I liked
  • It shows what is really on the wire, down to individual sample points drawn as dots.
  • Four times the capture window at the same sample rate (400 ms against 104.755 ms at 2.5 MS/s).
  • 42 bundled decoders, open source and still being updated.
  • Two triggers with protocol triggering, where the SL2 has edge and level only.
  • Selectable logic levels and much faster data fetch.
What I did not like
  • Still four channels, the same as my 2010 SL2.
  • One logic level for all four channels and no signal generation (the SL2 had it).
  • Bulky hook probes and Micro-USB on a 2025 design.
  • Update banners that take screen space in every capture.
Verdict
Faster edges, smarter triggers and a bigger buffer: the SE254 delivers all three. But the biggest difference turned out to be trust. When the SL2 runs out of headroom it doesn't show you a mess, it shows you a believable wrong answer, and that can cost you an evening chasing a bug in the wrong place. The SE254 showed what was really on the wire in every capture.
The SL2 is not obsolete: on slow buses, PWM and shift registers it matched the SE254 number for number, and its software can still learn new tricks. But if you debug anything fast, or anything where a convincing wrong answer is expensive, the SE254 is worth the upgrade. At 95 € it's an easy decision.
Read the full review
Everything above is covered in detail in the blog post, including the setups, all the PWM measurements, the I2C bit-slip analysis, the SPI aliasing explanation, the decoder port story, the software comparison and the full score justifications:
Thanks to element14 for the RoadTest and to Ikalogic for the SE254. More of my projects: Diagno, Wattson and grgelectric.com.
  • The Scanalogic SL2 was the first logic analyiser I ever had. It made such a difference being able to see the signals for the first time! A great piece of kit. Nice to see the company still going and still creating nice hardware.
