3D Printing
3D Printing
Blog Manual Solder Paste/Flux Extruder
  • Author Author: milosrasic98
  • Date Created: 17 Dec 2023 8:42 PM Date Created
  • Views 1854 views
  • Likes 12 likes
  • Comments 6 comments
  • 3d modeling
  • solder
  • soldering
  • tool
milosrasic98
milosrasic98
17 Dec 2023
Hi!
So I've had an arm for extruding solder paste out of a syringe that I got on AliExpress, and I loved using it.
But, as you can see from the picture, it broke only after a few weeks of use... I tried gluing it back together, but it didn't work and it just broke again. The whole thing looked rather simple, so I decided to just model out my version and print it out. I ended up making 2 versions, one that uses a small bearing and one without any bearings. Both share the exact same parts except the center rotating nut which is just an adapter to one version or the other.
Here are the pictures of the bearing-free version:
You can see the version with the bearing below, it also uses 2 additional M4 screws. I made that one first because I saw those bearings on my table when I got the idea, but from a functionality standpoint, they're exactly the same.
If you wanna print your own version, you can find all of the files here: https://www.printables.com/model/684211-manual-solder-flux-paste-dispenser-extruder
I love making 3D printed tools for my workshop since that means I can customize them to my liking, please share if you have any cool 3D printed tools below! Besides this, I have a 3D-printed USB microscope stand as well as a lot of small 3D-printed spools for jumper wires.
Milos
    genebren over 2 years ago
    That looks pretty cool!  What type of filament did you use?  Just to understand better, you grasp the syringe and the handle and squeeze with your fingers to dispense the flux? Also, is the syringe plunger cut down to allow your new plunger to enter the syringe, or is the special syringe for machine dispensing?
  • milosrasic98
    milosrasic98 over 2 years ago in reply to genebren
    Thanks! PLA+ from Creality. Yup, that's how you hold it, and the amount/flow is easily controllable by pressure because of the leverage. This syringe comes without a plunger at all, so at my last work place, we always resulted having plunger screwdrivers hahaha.
  • milosrasic98
