3D Printing
3D Printing
3D Printing Forum I need a free 3D printer
  • Subscribers 343 subscribers
  • Views 681 views
  • printer
  • 3d
  • free
  • electronics
if any of you have a free 3D printer and dont need it or dont want it please let me know and ill take it off your hands. I know most people will want money for it but if you just dont want it anymore and its free please let me know thanks.
    e14 Contributor over 12 years ago +1
    The parts for a printer are relatively easy to come by - steppers and such can be found in many types of old ink-jet printers, etc. The support rods will be a little harder to find although you can use…
  • PaulMakesThings
    PaulMakesThings over 12 years ago
    You might have better luck asking for parts. I've gotten many of the needed components for free, steppers, drivers, extruder parts, belts, pulleys ect. If you have a local hackerspace or makerspace that might be a good place to try. It's going to be hard to get a readily assembled working one for free.
    The parts for a printer are relatively easy to come by - steppers and such can be found in many types of old ink-jet printers, etc. The support rods will be a little harder to find although you can use roller-skate bearings for many designs needing sliders (Delta) or axis separation (Polar). Many designs can use printed spindles and braided fishing line to eliminate the need for toothed belts and gears. The parts that are most difficult to make for yourself will be the extruder/hot end set and the electronics - these are most often simply migrated to the next build since they are fairly standard at the current state of the art. You can build those yourself using an Arduino Mega, RAMPS-equivalent board and some Pololu-equivalent drivers. The power supply and limit switches can be obtained from a surplus computer or similar sources.Paul's suggestion ot get with your local hackerspace is a good plan.
    @Kalani - wow i hadnt thought of that. I'll be hitting the car boots/garage sales and picking up parts for next to nothing lol.
  • afoste12
    afoste12 over 12 years ago
    What purposes would you specifically use your printer for?
