3D Printing
3D Printing
3D Printing Forum Building a 3D printer out of Hp G85 Office jet printers
  • Replies 16 replies
  • Subscribers 341 subscribers
  • Views 2793 views
Hello there my friends... so i saw these 3D printer things... and i thought it would be cool to try to make one... now i have no background with Arduino at all... but i do have a little bit of knowlege when it comes to CNC's... see my father purchased 6 of these Hp G85 office jets this was a loooong time ago at least 12 years ago recently the last of them died and was replaced with a newer inkjet...
and so with the permission of my father i started disassembling one of these printers to see if they could be of use...
parts of notable significance
steppers 2 steppers per printer... both have encoders not sure if they are useful to me though
rails there are 2 rails per printer aswell
belts two belts per printer and gears/ sprockets to go with the belts...
cold cathode light (from the scanner) useful for other projects and possibly for built in lighting on the 3d printer...
Glass plate from the scanner
various springs and stuff
that seems to be it
so my question is could i use 2-3 of these printers to build a 3d printer
will the steppers be adequate?
if not what steppers are recommended?
where can i find a mc-mega dev board and a RAMPS Sheild?
my goal design is to build one similar to the portable one ben heck built... although mine wont be portable...
any information you have to share with me would be greatly appreciated!
    e14 Contributor over 12 years ago in reply to e14 Contributor +1
    That sounds like a Cartesian-format layout (take a look at the Mendel or Prusa i3) and definitely the Arduino MEGA + RAMPS is a good way to go. Most of the other common boards (RAMBO, etc) are just combined…
  • Nate1616
    Nate1616 over 12 years ago in reply to e14 Contributor
    For your Arduino  you will need the Mega 2560 or some sort of clone like the Tosduino Mega 2560(http://www.lulzbot.com/?q=products/tosduino-mega-2560).  As far as the ramps goes you will want the Ramps 1.4 as this is the newest iteration(http://www.lulzbot.com/?q=RAMPS-1.4-Assembled-wo-Wires-or-Connectors).  Don't forget you will need a stepper driver for each motor and by the looks of your drawing that would be 5 motors(2 z-axis, 1 x-axis, 1 y-axis, 1 extruder).  For the x and y axis this is typically driven by a belt and pulley system were the z axis has threaded rods an each side of the x axis carriage.  You might be able to find the parts cheaper on ebay than the 2 links I have posted as I was just trying to show you want to get.
    Nate
    e14 Contributor over 12 years ago in reply to Nate1616
    Thank you Nate that was the information i was looking for... i actually have most of the components for this design... the main part was the mega board and the ramps i i belive i can get ahold of the drivers for about $15 and the acme screw with the nuts for about $60 and that will cover both sides... Mentlegen i believe we have a $300 3d printer! although the fact that i can build the frame for pretty much nothing but time that is helpful...
  • Nate1616
    I also want to mention is, don't forget to start looking at the software side of the printer.  What firmware you will use on the board.  What slicing and computer/interface software will be used.  I will give you my advice  on these but still do your own research.  For the firmware I would go with Marlin and slicing would be Slic3r and interface would be Printrun.
    Nate
    thank you nate! im gonna start looking in to those frimwares now
    i think i got one of my my friends interested so he is gonna take care of the arduino part of it...
    Always a great idea to bring in others with expertise that compliments your own. Your design itself looks much like many of the various Mendel-etc variations. Because you have access to a plastics shop for manipulating the frame components, you can be more artistic in your expression than most - http://farm8.staticflickr.com/7242/7184941946_938a349924_z.jpg is a good example of what someone with Plexiglass and some LEDs has done to improve the "curb appeal" of their Mendel variation. Be creative and make a bold statement with your design!
    Kirk
    at this point i want to see if i can get the thing working ... once that happens and im more familliar then ill do some more artistic stuff XD
