3D Printing
3D Printing
3D Printing Forum What is the best program for converting .stl to .x3g
  • Subscribers 344 subscribers
  • Views 32584 views
  • 3d print
mads391i
mads391i over 9 years ago
Hi
I'm having som problems making my files into .x3g.
Could somebody please help. That would be great.
    balearicdynamics over 9 years ago +2 verified
    Hello Mads, as far as I know it seems that the better softare to make the conversion easily is the open source Makerbot replicator application. I have not investigated if this can work without any hardware…
  • mads391i
    mads391i over 9 years ago in reply to balearicdynamics +2 suggested
    Thanks a lot read the articel and went on to another link: How to Save a Model | MakerBot Desktop (Software) | MakerBot Support , here i found how to do. I'm going to check if it works later
  • selajon
    selajon over 7 years ago +1
    SelfCAD can also do it very well. You can convert any 3d model into any format given.
    0 balearicdynamics over 9 years ago
    Hello Mads,
    as far as I know it seems that the better softare to make the conversion easily is the open source Makerbot replicator application. I have not investigated if this can work without any hardware but I suppose yes as well as Cura and Repetier can do. I suggest you to read this article: https://support.makerbot.com/learn/makerbot-desktop-software/using-makerbot-desktop/how-to-prepare-a-model-for-printing_… it is the better explained I have found until now.
    Hope this can help. Enrico
  • mads391i
    0 mads391i over 9 years ago in reply to balearicdynamics
    Thanks a lot read the articel and went on to another link:How to Save a Model | MakerBot Desktop (Software) | MakerBot Support , here i found how to do. I'm going to check if it works later
  • selajon
    0 selajon over 7 years ago
  • ogre56
    0 ogre56 over 7 years ago in reply to balearicdynamics
    Awesome!!! I got a dual extrusion MonoPrice 11614 for $100 and once I found your post was up and running in just a few minutes.
    Thanks!!!
    Larry
  • bravebraddy
    0 bravebraddy over 4 years ago in reply to selajon
    Also faced the same problem. I did not like the work of SelfCAD, but I contacted the manufacturer and he suggested that it is better to use Invertor and do everything in it. And he suggested where I had errors in the settings. So, you can do the same:)
