3D Printing
3D Printing
3D Printing Forum Need help! Printer not printing good circles
  • Subscribers 343 subscribers
  • Views 3015 views
  • help
  • 3d cad
  • leonardo da vinci
  • xyz
  • supplier_xyz
  • xyzprinting
  • 3d print
braedan
braedan over 8 years ago
Hello element14 community,
     I have a da Vinci Mini from XYZprinting. It was a Christmas present but it would not print circles, so I sent it back. This is my second one and I have not had any issues with it for over a year. Now this one is also starting to have the same issue. Two opposite sides will be flat an the rest of the circle will be just fine! As if right now the issue is not severe, but it becoming exponentially noticeable. I've been using XYZprinting black PLA filament on the "good" preset. The bed is unheated and is covered with (old?) masking tape. The filament has been stored in the open, no where special. I have never added any grease or lubricant. The belt seems well tightened and I cannot spot any slipping. Where is my problem coming from?! I haven't been able to find any helpful sources on the internet, please help!image
  • rachaelp
    rachaelp over 8 years ago in reply to balearicdynamics +3 suggested
    Hi Breadan, To add to the great info balearicdynamics has already given, my guess would be, looking at that picture, one of the axis is becoming stiff and causing the stepper to miss steps. I suspect cheap…
    balearicdynamics over 8 years ago +2 verified
    Hello Braedan! I am sorry to read about this issue and I am sorry on what I am answering you based on my experience. Before I started building my own 3D printers, most of them based on the Prusa design…
  • braedan
    braedan over 8 years ago in reply to balearicdynamics +1
    Thank you Enrico for your lengthy response! It means a lot that someone was willing to put in the time to write this. Seeing as my history with XYZprinting is almost identical to yours, I think I'm almost…
    0 balearicdynamics over 8 years ago
    Hello Braedan!
    I am sorry to read about this issue and I am sorry on what I am answering you based on my experience. Before I started building my own 3D printers, most of them based on the Prusa design I explored the possibility to buy a more expensive but reliable commercial 3D printer. The choice was just because I need to use the printer and not play making and molding the printer itself.
    I bought a XYZ, not the mini but the bigger model. My luck was I bought it from Amazon!
    I used it for about a month, just the time to understand how the principle works and how the 3D printer produces parts; take in account that the bigger model has a hot bed that I always strongly suggest for a lot of reasons. Then... The surprise#1, printer x-y motion started making wrong circles - become ellipses - but with a good measure also the square and cubes was not precise.
    After  making a lot of specific tests, filming and logging every step and producing an incredible amount of media demonstrating that it was a problem of the printer I entered the next level gaining the surprise#2: I have no idea if it is because I am in Spain but the XYZ technical support always answered me only one time a day, and by email only. In about a week - and time passes, imagine the feeling is things you need are continuously delayed and the time you planned to do a job is spent to understand why the printer does not work...
    In the meanwhile they suggested me a lot of silly potential issues like the x-axis belt tensioning, a wrong setting in the parameters here and there etc. etc. The final result was surprise#3 : they suggested me to send the printer back to them - covered by warranty - for a replacement in about one month.. I ignored this suggestion because, thank to Amazon, in three days I sent back the printer and bought a new one.
    And I won surprise#4, I experienced the same identical issue - despite the newest firmware version - in about a month. My definitive solution was to send back the second XYZ printer, got back my money and bought a Prusa aluminium from Geetech that worked for a couple of years (some thousand of hours) with minimal and easy to apply repairing. Then I sold this printer to a friend that moved it from Spain to Italy, I bought a new one last year when I was living in the Netherlands, moved it here in Spain again in the mid of this year and bought a second one. And I am using the 3D printers as one of the most important parts of my prototyping jobs, as well as my CNC.
    Acquiring experience on the 3D printing technology I have discovered that IMHO the guys that created the XYZ printers made a couple of almost hidden but dramatically wrong project errors in their design; this factor, together with the very bad idea - always a personal opinion - of making a 3D printing software specific for their devices makes this product unfortunately not reliable. It is sad to discover that the same issues and problems I found on the device in 2015 it is again present, suggesting me that probably my idea of a project issue never solved maybe confirmed.
    You can read some more information on the suggestions and some tips I have experienced with time and usage of 3D printers in my post Review: 3D Printer Prusa Aluminium I3A Plus
    Enrico
  • rachaelp
    0 rachaelp over 8 years ago in reply to balearicdynamics
    Hi Breadan,
    To add to the great info balearicdynamics has already given, my guess would be, looking at that picture, one of the axis is becoming stiff and causing the stepper to miss steps. I suspect cheap linear bearings or linear shafts which start off ok but then start to get some play which then causes them to twist and bind as they move. I unfortunately had an experience with a bad 3D printer a few months back, all sorts of issues, badly running linear bearings on poor linear shafts was one of the many issues....
    Best Regards,
    Rachael
  • braedan
    0 braedan over 8 years ago in reply to balearicdynamics
    Thank you Enrico for your lengthy response! It means a lot that someone was willing to put in the time to write this. Seeing as my history with XYZprinting is almost identical to yours, I think I'm almost ready to move onto an open-source platform like you did. If I cannot fix the problem in a cost effective manner I plan on selling the printer, and all of its accessories, to a friend of mine hoping to get into the hobby. I'm currently looking at ~$300 printer kits, like the TEVO Tarantula which has good reviews. I will definitely be reading your review.
    Thanks again!
         -Braedan
  • braedan
    0 braedan over 8 years ago in reply to rachaelp
    Thanks racaelp,
    I'll be looking into your solution. Unfortunately I cannot open the printer with out major difficulty, so I will try to lubricate all visible shafts and sliders ( all of which have not been treated in awhile).
    Braedan
  • gam3t3ch
    0 gam3t3ch over 8 years ago
    Have you tried different slicers?
  • kayluss007
    0 kayluss007 over 8 years ago
    i had the same thing happen to me when i got my 3d printer kit a year ago and it did it from the start. i just assumed it was the printer wasn't capeable of doing circles sence i never had a 3d printer before and didn't know much about how they worked so i didn't do anything about it untill i started to notice a buzzing sound everytime the motors made a step then i started to check all the connections from the motors to the board and found that one of the 4 wires in the plastic housing of the plug to the board was loose so it was moving in and out of the housing when the printer was running causing the problems so i replaced the stepper motor wire going from the motor to the board and it now prints perfect circles and no more buzz sounds when it takes a step..its no longer skipping steps and printing perfectly...hope this helps
