3D Printing
3D Printing
3D Printing Forum how to my A8 3D printer to print
  • Replies 7 replies
  • Answers 3 answers
  • Subscribers 342 subscribers
  • Views 1521 views
  • 3d printer
fatguyl0l
fatguyl0l over 8 years ago
Hi I just got a new A8 3D printer for the Holidays. I finished setting it up checked all the motors every thing moves as it should. Then when I go to load gcode into the printer it will say it's printing but will not move any advise. Here is what I am working with.
imageA8 3D Printer Installation Instructions.pdf
    dougw over 8 years ago +2 suggested
    When it starts, the nozzle needs to heat up to about 190 degrees or more which can take a few minutes. Also if it has a heated bed the bed can take quite a while to heat up. Nothing moves until the correct…
  • fatguyl0l
    fatguyl0l over 8 years ago +2
    Yup bad sd card works great thank you so much for all your help it's nice to bounce ideas back and forth between some one thank you.
  • fatguyl0l
    fatguyl0l over 8 years ago in reply to dougw +1
    everything is at temp before I run it from what I've seen so far it's something with the gcode it's not reading a code that it needs and after I try to run it will remove all the code on the file and leave…
    0 dougw over 8 years ago
    When it starts, the nozzle needs to heat up to about 190 degrees or more which can take a few minutes. Also if it has a heated bed the bed can take quite a while to heat up. Nothing moves until the correct temperatures are reached. Check to see if the right things are heating up.
  • fatguyl0l
    0 fatguyl0l over 8 years ago in reply to dougw
    everything is at temp before I run it from what I've seen so far it's something with the gcode it's not reading a code that it needs and after I try to run it will remove all the code on the file and leave it blank but thank you so much for the help.
    0 dougw over 8 years ago in reply to fatguyl0l
    gcode needs to be created specifically for your printer. Are you using the example that came with the printer?
    Here is a pretty good guide to the A8:
    https://www.propwashed.com/anet-a8-build-guide-and-1st-print/
  • fatguyl0l
    Nope still just shows that print on the lcd won't move and then deletes the gcode that I try to run. well I'm at a dead end I've even scrolled through the gcode on the sd card that came with it to see if there was something not being added in and no differences between the two just xyz if nothing else going to see if maybe it's the sd card that's all I can think that might cause the problem.
  • fatguyl0l
  • gadget.iom
    0 gadget.iom over 8 years ago in reply to fatguyl0l
    Thanks for the feedback with your solution. Chances are that it might just help somebody else in the future. image
    Paul.
  • enriqueiglesias
    0 enriqueiglesias over 8 years ago
    You may be wondering how long it takes to assemble this printer and you may not like the idea of assembling it in the first place. But if you are anything like me you will have a blast putting this printer together and you will also learn how a lot about how a 3D printer works. for more issues you can also search hp printer offline windows 10  and you will get the help.
