3D Printing
3D Printing
3D Printing Forum 3D Slicer Software
  • Subscribers 340 subscribers
  • Views 877 views
  • cuter
  • 3d
  • laser
3D Slicer Software
timswift
timswift over 11 years ago
Would it be possible to use 3D slicer software (for a 3D printer) and a laser cuter to cut out the layers (instead of a 3D printer)?
Tim
  • bradnorwood
    bradnorwood over 11 years ago +1 suggested
    I think so, I use repetier, and it uses slic3r, repetier allows you to choose no extruder for things like cnc, slic3r lets you tweak it, you will have to read up or play with it to figure out the settings…
  • bradnorwood
    0 bradnorwood over 11 years ago
    I think so, I use repetier, and it uses slic3r, repetier allows you to choose no extruder for things like cnc, slic3r lets you tweak it, you will have to read up or play with it to figure out the settings, it helps to already use this in 3d printing before attempting cnc etc.
  • timswift
    0 timswift over 11 years ago in reply to bradnorwood
    Thanks Brad.
    I was thinking that instead of 3D printing i could use a laser cuter and make large objects out of foam.
    Tim.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago in reply to timswift
    what do you call large Tim
    even a laser cutter to cut upto 8"x11" will set you back 450$$ for a cheap one (China import) and rapidly gets into thousands of dollars for a good one with a bigger work area
    you also will need a ventalation system and cooling (Water cooling) as these use CO2 Laser tubes for the most part, although you can get some really slow ones that use Laser diodes upto a few hundred milliwatts
