    • Avnet Boards Community
3D Printing
3D Printing
3D Printing Forum Is this the sound of a dead linear bearing?
  • Replies 13 replies
  • Subscribers 327 subscribers
  • Views 5059 views
baldengineer
baldengineer over 2 years ago
This video is from a Prusa MK3. It used to be intermittent. But now, whenever the y-axis moves, it makes this zip-tie noise.
I think the source is this bearing, but the high-pitched sound makes it difficult for me to localize.
Does it sound like a dead bearing to you?
  • baldengineer
    baldengineer over 2 years ago +5 suggested
    New idler arrived. I used my backup mount to replace the stripped original. Currently, I am printing a PETG replacement for my backup PLA part. But the printer is working well, and no more binding…
    dougw over 2 years ago +3
    It sounds like you might even be missing some balls from the bearings and there is not enough grease in the race. Try lubrication. Grease may be better than oil for such a stutter. Also check the rod for…
  • hlipka
    hlipka over 2 years ago in reply to dougw +3
    No, the Y-belt idler is not symmetrical. Since the MK3S is open source, you can check the files here: https://www.printables.com/model/57217-i3-mk3s-printable-parts/files . When you click on the STL you…
  • hlipka
    0 hlipka over 2 years ago in reply to dougw
    No, the Y-belt idler is not symmetrical. Since the MK3S is open source, you can check the files here: https://www.printables.com/model/57217-i3-mk3s-printable-parts/files . When you click on the STL you get a 3D viewer.
    When mounted upside down, the pulley sits too high which might lead to additional stress then the bed is in the most-front position.
  • baldengineer
    0 baldengineer over 2 years ago in reply to hlipka
    Oh, no “might” about it. ;) I have a dead bearing to demonstrate. hehe.
  • baldengineer
    prusa with replacement 3d printed part
    But the printer is working well, and no more binding noise from the incorrectly mounted idler! (go figure)
    • Vote Up +5 Vote Down
