3D Printing
3D Printing
3D Printing Forum What Type of 3D Printing Filament Material Do You Use?
  • Replies 17 replies
  • Subscribers 341 subscribers
  • Views 6793 views
  • 3D printing filament
rscasny
rscasny over 2 years ago
  • baldengineer
    baldengineer over 2 years ago +3
    About a year ago, I switched from PLA to PETG. Strong prints, less warping, and it isn't excessively expensive compared to PLA. I also have several bright colors in ColorFABB's nGEN. That's probably…
  • strb
    strb over 2 years ago +1
    To me it really depends on the application I will use the 3D printed object. PLA is the "go to" material for general purpose stuff without particular requirements, probably 80% of what I print PETG if…
    Jan Cumps over 2 years ago in reply to dougw +1
    "print a hole" is meta!
    dougw over 2 years ago
    PLA all the way. It is the most benign.
  • misaz
    misaz over 2 years ago
    What about chocolate?
  • hlipka
    hlipka over 2 years ago
    I need to select multiple ones: I use PLA and PETG regularly, ABS or ASA sometimes when needed, and TPU or Polycarbonate when the object requires it.
  • fmilburn
    fmilburn over 2 years ago
    PLA, usually the cheapest one that sells in large volume in the hope it is fairly fresh.
  • baldengineer
    I also have several bright colors in ColorFABB's nGEN. That's probably my favorite filament to print with, but it isn't cheap.
  • meera_hussien
    meera_hussien over 2 years ago in reply to baldengineer
    I used to print with PLA, but now slowly moving to PETG.
  • ggabe
    ggabe over 2 years ago
    PLA, Hatchbox and Overture Pro.
  • balajivan1995
    balajivan1995 over 2 years ago
    In my office, when designing enclosures for electronic items we use PLA for initial iterations and ABS for final mockup.
  • strb
    PETG if I need a little bit more heat resistance or ABS if I need heat resistance and ease of post proceessing (it can be easily glued,can be machined beautifully and it's easy to smooth)
    TPU for compliant or "soft" objects
    PA+CF because it's cool, almost never used except for some small part on my RC car where high mechanical properties are essentials
  • rsjawale24
    rsjawale24 over 2 years ago
    I use PLA. Never tried other filaments. But would love to give other filaments a try
