3D Printing
3D Printing
3D Printing Forum CNC servo control
  • Replies 19 replies
  • Subscribers 343 subscribers
  • Views 4928 views
CNC servo control
antiobsolescenttoymaker
antiobsolescenttoymaker over 9 years ago
can anyone point me in the right direction?
I recently picked up a nice biotech xyz table.
I've confirmed that the components themselves work but want to convert it into a CNC router / 3D printer.
The table uses med size DC servo motors for all movement and has the original PSU.
I have looked all over and have yet to find an arduino based solution for a servo CNC
    balearicdynamics over 9 years ago +4
    Hello Genesis, I think you should be aware that it is not useful a 3D printer + CNC on the same machine. First you should define better your problem and your target, please else it is very difficult to…
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago +3
    Your biggest problem is you dont appear to have a suitable "Servo Controller", many of the new "Servo Motors" have a controller built in and will accept step and direction signals in the same way as a…
    michaelkellett over 9 years ago in reply to antiobsolescenttoymaker +2
    Generally speaking the processors you are talking about are not the first (or second or third) choice for linear motor control. TI make suitable processors and low cost dev boards and also publish a lot…
    balearicdynamics over 9 years ago in reply to Robert Peter Oakes
    Hi Peter, you are perfectly true with a very clear and detailed explanation.
    Making a hybrid CNC & 3D Printer is an idea I have already though, but always discarded as the cost to make a similar tool the consts vs benefits analysis is loosing. Not only we should consider that there are some components not fully compatible in one case than the other. This means that every time moving from a 3D print job to a CNC milled part the result is at least:
    1. Replace the milling tool with the extruder (need calibration and other delicate operations)
    2. clean the area from milling for 3D printing
    3. remove the metallic CNC base and replace the bed
    4. Managing a lot of connections some excluding the other
    There are other intuitive aspects that are complementary and very different that needs to have a a bigger machine (at least) and more space and a relatively complex electronic architecture and a powering system to make the final result just an academic challenge and not a really useful cheap tool.
    Enrico
    Robert Peter Oakes over 9 years ago in reply to balearicdynamics
    All very good points
    To add to this
    You can't build either cheaper that one or the other or even the same price. The cost will be more than the more expensive but should not be double. With proper planning you can build it as a hybrid but you need to select the right software to drive it. Also you need to build it to the strength needed for the CNC Router and therefor need to know the load of the cutter, so are you going to just use a dremel style cutter or something much bigger like a Bosch Colt woodworking router. or are you just planning on doing wood / plastic and perhaps a little PCB milling ?
    As Enrico pointed out, there are considerations needed when considering a hybrid, calibration being the most critical, the heated bed should be removable and or protected when CNC Routing, the head will need to be switched between the extruder and the cutter, this is where alignment dowels may come in handy to help accurate assembly and therefor easier calibration, the router is not so critical but the printer is, it need a flat bed or software to compensate for an uneven one.
    You need a controller that is a superset of one or the other (So the 3D printer style but more power for when doing CNC Work)
    I have one of the ST Micro 3D printer reference boards coming so I will see how well it can meet the needs, it runs Marlin and supports 3 extruders, 6 stepper motors etc but only upto 3 Amp per winding (Enough for small CNC router and pretty much any 3D printer or laser cutter), as it has 6 stepper drivers it will handle a 4th axis in CNC mode too. STEVAL-3DP001V1 STMICROELECTRONICS, REF DESIGN BRD, 3D PRINTER DRIVER, Newark element14 Canada
    The price of the only board you mention is about 9 times the single controllers price image
    Enrico
    yes but look at its specifications
    32Bit vs 8 bit
    6 steppers vs4 or 5
    3 hot ends at 8Ams each (Not total)
    3 heat zones at 20A each, not total and support for 24V heaters here
    WIFI Enabled
    now find one with similar specifications at 9 times less ??
    Pretty much everything is built in
    peter
    Peter agree and if I would try building an hybrid this is the right one IMHO. The point is about the pricing in general. I am almost sure that the total price maybe heigher than the two tools separate
    Enrico
    peter I saw your videos on this gigantic building many times and I really love them. Well done, clear and you have done a very good job. Every time I see them I have a question. Why in a so well done structure good and precise the shaft is just something like a Dremel o Proxxon or similar? Is not the case to include a motor controlled spindle? I have a 30x30 cm mill machine but the better part is the water cooled spindle 800-300 rpm. Or I am wrong respect the kind of material that should be worked ?
    Enrico
  • antiobsolescenttoymaker
    antiobsolescenttoymaker over 9 years ago in reply to Robert Peter Oakes
    Thank you and Yes, swapping the servos for steppers is what i'm currently doing.
    The small pcb's are just interface boards with no ic's
    Well I do have way better than a dremel, I have a Bosch Colt 1HP 30,000 RPM woodworking router, still not as good as a purpose designed spindle with a proper ERxx collet etc but to keep things simple...
    I have no budget to buy a nice spindle, all except the Colt was donated by my sponsors to make the videos, No Payment aside from the gift of the parts and I dont get paid to create any of my content so I rely heavily on generous sponsors but none so far have sent me a spindle or even carry one as a product surprisingly... maybe soon image, I do have a 3.5W laser that will be added from Banggood and I am looking forward to integrating that image/
    and I get very little from Google Adsense, barely enough to pay for the internet access.
    I hope that clarifies your question
    Hello Peter,
    all is clear. Me too I am veeeery sensible to this kind of problems (i.e. $$$) but I thought it was some different reason. My mill machine - at the moment in standby due the new lab reset - has a spindle like what I have described but I got it as partial development support from a customer years ago. And I was astonished discovering that it was about 400$ to replace one image
    For some reason I was thinking there was a more technical reason.
    Enrico
