3D Printing
3D Printing
Documents Octoprint Relay board
  • Author Author: rctho
  • Date Created: 19 Dec 2017 1:10 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:27 PM
  • Views 3003 views
  • Comments 18 comments
I tested this relay board out on a breadboard. seems to work well. I had to move some components around to scale it down to the size board i had laying around. This is for a remote switch for the 3d printer i got. I'm going to connect it to the gpio pints of the raspberry pi/ octoprint server to shut it down remotely.
I'll test it out on a something else like a light before the printer to ensure i don't fry it. Fingers x'd.
  • octoprint
  • diy pcb
  • relay test
  • 3d printing enhancement
  • 3d print
  • rctho
    rctho over 8 years ago +3
    I finally got this thing up and running and it works great turning the printer on and off. After the breadboard prototype, i had to move stuff around and went a lil' off track from the original design…
  • carmelito
    carmelito over 8 years ago +2
    This is a great idea.Hoping you will post an update, as soon as you have it working with your 3D printer..Thanks
    jw0752 over 8 years ago +2
    Hi Craig, This is a good example of planning and testing prior to building. With this approach you have a much better chance of success. John
  • rctho
    I finally got this thing up and running and it works great turning the printer on and off. After the breadboard prototype, i had to move stuff around and went a lil' off track from the original design that set me back a bit but i finally got it to work. Octoprint has a PSU plugin that saved me from having to edit any config files. I just setup the reset function in the plugin settings by adding the gpio pin to trigger the relay board and thats it.
    Off to a good start finishing up some old projects. Time for some remote printing. I want to print a case but i only want to have one power cord to power everything. Power and ethernet coming in and printer and camera going out. Maybe a power switch too. Any suggestions?
  • rctho
    jw0752 over 8 years ago in reply to rctho
    Thanks for sharing the finished project. Looks good.
  • rctho
    rctho over 8 years ago in reply to jw0752
    Thanks John.
