3D Printing
3D Printing
Documents Octoprint Relay board
  • Author Author: rctho
  • Date Created: 19 Dec 2017 1:10 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:27 PM
  • Views 3003 views
  • Comments 18 comments
I tested this relay board out on a breadboard. seems to work well. I had to move some components around to scale it down to the size board i had laying around. This is for a remote switch for the 3d printer i got. I'm going to connect it to the gpio pints of the raspberry pi/ octoprint server to shut it down remotely.
I'll test it out on a something else like a light before the printer to ensure i don't fry it. Fingers x'd.
  • octoprint
  • diy pcb
  • relay test
  • 3d printing enhancement
  • 3d print
  • rctho
    rctho over 8 years ago +3
    I finally got this thing up and running and it works great turning the printer on and off. After the breadboard prototype, i had to move stuff around and went a lil' off track from the original design…
  • carmelito
    carmelito over 8 years ago +2
    This is a great idea.Hoping you will post an update, as soon as you have it working with your 3D printer..Thanks
    jw0752 over 8 years ago +2
    Hi Craig, This is a good example of planning and testing prior to building. With this approach you have a much better chance of success. John
  • rctho
    rctho over 8 years ago in reply to Robert Peter Oakes
    Thanks Peter. I'll give that a shot. I wanted to try to power both the pi and relay with the same line but somehow divide it with a 5v transformer/regulator and the relay with a common ground, but you're saying that's not a good idea?
  • Robert Peter Oakes
    Robert Peter Oakes over 8 years ago in reply to rctho
    You should not need an opto isolator but you should be aware of keeping the POWER current away from the microcontroller current
    So power the relay / LEDs from a separate supply to the PI and just share a common ground
    Regards
    Peter
  • rctho
    rctho over 8 years ago in reply to mcb1
    The voltage is 12 with 7 amps. You think that will require optocouplers? Not gonna lie, I don't know what that is. I'm going to search online then see if there are any kicking around in the lab in case i need them.
  • rctho
    rctho over 8 years ago in reply to jw0752
    Sure is. i had to learn it the hard way though image
  • rctho
    rctho over 8 years ago in reply to carmelito
    Thanks carmelito Will do as soon as it's done.
    mcb1 over 8 years ago
    What voltage is the relay contacts going to switch.?
    If you are switching mains voltages then using optocouplers might be the safer method of ensuring isolation.
    Hi Craig,
  • carmelito
