Artificial Intelligence and Machine Learning
Forum Which AI tool do you use for documentation?
Join Artificial Intelligence and Machine Learning to participate - click to join for free!
  • Replies 26 replies
  • Subscribers 93 subscribers
  • Views 1298 views
  • artificial intelligence
prajaktaa
prajaktaa 2 months ago
I am curious to know that which AI tool the community members are using to create or improve technical documentation.
Whether it is for the project documentation, API documentation any troubleshooting guides, or internal knowledge base articles, AI has become a helpful assistant for many professionals.
Some popular options include ChatGPT, Claude, Gemini, GitHub Copilot, Microsoft Copilot, and Perplexity, but each has its own strengths and limitations.
My questions are:
  • Which AI tool is easy to use for documentation?
  • What type of documentation do you create with it?
  • What do you like most about the tool?
  • Have you found any limitations or challenges?
  • Do you rely on AI-generated content as-is, or do you always review and edit it before publishing?
I'd love to hear about your workflow, practical experiences, and any tips or best practices you've discovered.
  • colporteur
    colporteur 2 months ago
    I received this table from a AI introduction course. It is the authors recommendation for the AI to the particular job.
    michaelkellett 2 months ago in reply to Jan Cumps
    Ready, Fire, Aim !
  • afernandez
    afernandez 2 months ago in reply to Jan Cumps
    The main sw desing regulations for critical systems like DO-178C,  AQAP-2210 and the basic V validation follow this schema, document your design first according to your system requirements, implement your solution and then document the final solution and the test that you was made to ensure that the requirements are satisfied. But I known that if work in a small or self made project this process may seem ineficiente.
    Jan Cumps 2 months ago in reply to afernandez
    The trades have moved on. Documentation 1st has never been efficient. 1980s are over Slight smile
  • afernandez
    afernandez 2 months ago in reply to michaelkellett
    Hi, I agree with michaelkellett . The documentation process should begin before you build your solution, as it helps ensure that the software or hardware you design is robust and meets the project requirements.
    On the other hand, when working on critical applications, as in my case, and especially when the solution needs to be certified, the use of AI tools may not be permitted during the documentation process. The author, reviewer, and approver must be identifiable individuals in order to ensure proper accountability and traceability.
    Generative AI tools can also show a tendency toward sycophancy or excessive agreement with the user. This can be a serious drawback when designing complex systems, because a good engineering process requires critical thinking, independent verification, and the ability to challenge incorrect assumptions.
    I don't use AI for documentation.
    For serious projects I will usually run separate hardware and software documentation  streams.
    The documentation starts before and CAD or IDE are used.
    The idea is to describe things before the tools start to get in the way. As the design progresses you develop the documentation and then the code/schematic etc.
    For example - if you will use a micro-controller you need to decide which one. To make a good choice you need to know what it is going to do - and the design notes (as I call them) are used to develop ideas and define them in increasing detail.
    It is generally accepted that very early design decisions often define most of the project - and so they are very important. If you use AI to do this you will have delegated most of the cost of the development in that first one page description you give the AI.
    Of course documentation written after the event is crazy - if you have to describe the design when its complete it should prompt you to at least wonder how you got there !
    I can't see where AI comes into a good design process - except as maybe a spell checker.
    I suspect that I am already in a minority - welcome to the 20230s - where AIs will use terawatt hours  of energy to produce peta Pages of output which other AIs will summarise down to .......
    • Vote Up +5 Vote Down
