Code Exchange
Code Exchange
Blog C++ 3 way compare
Join Code Exchange to participate - click to join for free!
  • Date Created: 15 Jul 2025 3:49 PM Date Created
  • Views 941 views
  • Likes 8 likes
  • Comments 7 comments
  • Modern C++
  • spaceship
  • c++26
  • c++23
  • c++
  • c++20
C++ 3 way compare
15 Jul 2025
task: Let's say that you are writing a C++ class, where the objects have to be sorted or compared.
In classic C++, you 'd write an operator overload for <, <=, == , !=, >= and >. In modern C++, you can get all that functionality with a single method: <=> (aka the spaceship operator).
If you provide an implementation for that operator, the compiler will derive all comparisons.
class compare_me {
 public:
    constexpr compare_me(int value): value{value} { }
    auto operator<=>(const compare_me& rhs) const = default;
 private:
    int value;
I'm using C++ default <=> implementation here. It will compare all the class data members - if they support comparison. In this example, the operator will compare the value data member.
If you can't (or don't want to) use that functionality, you can provide your own implementation. For the rules on how default works, see Default comparisons order.
This is functionality you get when providing this single operator overload in your class:
    constexpr compare_me value_1(1);
    constexpr compare_me value_2(2);
    constexpr compare_me other_value_2(2);
    constexpr compare_me value_3(3);
    std::cout << (value_1 < value_1) << std::endl;
    std::cout << (value_1 < value_2) << std::endl;
    std::cout << (value_2 < other_value_2) << std::endl;
    std::cout << (value_2 <= other_value_2) << std::endl;
    std::cout << (value_2 >= other_value_2) << std::endl;
    std::cout << (value_2 == other_value_2) << std::endl;
    std::cout << (value_2 != other_value_2) << std::endl;
    std::cout << (value_3 < value_2) << std::endl;
    std::cout << (value_3 <= value_2) << std::endl;
    std::cout << (value_3 > value_2) << std::endl;
    std::cout << (value_3 >= value_2) << std::endl;
Result:
false
true
false
true
true
true
false
true
false
false
true
true
Complete code:
#include <compare>
#include <iostream>
class compare_me {
 public:
 private:
    int value;
int main() {
    std::cout << std::boolalpha << std::endl;
    std::cout << std::endl;
Bonus: use STL sorting algorithm on a container of our objects
This is functionality that you get when you provide the <=> operator.
Example: execute a few STL algorithms on an an array of (initially) unsorted objects
#include <array>
#include <algorithm>
    std::array<compare_me, 4> sort_me {2, 3, 2, 1};
    for(const auto& cm : sort_me) { std::cout << cm << " "; }
    std::cout << "sorted? "<< std::is_sorted(sort_me.begin(), sort_me.end()) << std::endl;
    std::sort(sort_me.begin(), sort_me.end());
    std::cout << "sorted? " << std::is_sorted(sort_me.begin(), sort_me.end()) << std::endl;
Output:
2 3 2 1
sorted? false
1 2 2 3
sorted? true
sorting algorithms used:
std::is_sorted()
std::sort()
By default, STL uses the < operator to sort. If you want to sort using other criteria, that's possible.
This snippet sorts the container from large to small:
std::sort(sort_me.begin(), sort_me.end(), [](const compare_me& a, const compare_me& b) {
    return a > b;
for (const auto& cm : sort_me) { std::cout << cm << " "; }
std::cout << "sorted? " << std::is_sorted(sort_me.begin(), sort_me.end(), [](const compare_me& a, const compare_me& b) {
    return a > b;
}) << std::endl;
3 2 2 1
sorted? true
Bonus 2: print a container of our objects
To support printing, I also provided an << operator for my class compare_me:
    friend std::ostream& operator<< (std::ostream& os, const compare_me& cm) {
        return os << cm.value;
You can then print an individual object to a stream (in this case: the standard output stream.
To print the full array of objects, you can use this:
Inspiration: MC++
attached: full code main20250719.zip
Thank you for reading.
    DAB over 1 year ago +1
    Nice algorithm Jan.
    Jan Cumps over 1 year ago +1
    My #Modern C++ blogs were inspired by Rainer Grimm's modernes c++ articles . Sadly, he has recently passed away. Forever thankful.
  • kmikemoo
    kmikemoo over 1 year ago
    That is SUPER cool! Thanks for sharing, Jan Cumps .
  • kmikemoo
