Code Exchange
Code Exchange
Blog How to Easily Burn a Binary File to an MSP430 Chip Using the LaunchPad
Join Code Exchange to participate - click to join for free!
  • Author Author: DaveYoung
  • Date Created: 15 Apr 2013 6:27 AM Date Created
  • Views 8358 views
  • Comments 15 comments
  • code_exchange
  • Code Exchange
  • programming
  • embedded
  • microcontroller
  • msp430
  • dyoung
DaveYoung
DaveYoung
15 Apr 2013
Often times someone other than the firmware designer on a development team needs to program a TI MSP430 chip.  An analog, apps, or test engineer, client; even an end user does not want to mess around with installing an entire IDE for a released firmware update.  There are too many settings and parameters to worry about, in addition to a heavyweight program which may require a paid license to be installed.
Thankfully, a Binary file can be created by Code Composer Studio.  A Binary file has everything a microcontroller needs to know in order to execute the program, and can be sent directly to the chip to be run.   Usign this file, a small computer program called Lite FET-Pro430 by Elprotronic can use the MSP430 Launchpad hardware to program a chip without the user having to face a single line of code. It's easy, free, and best of all, leaves little room for error.
The video below shows how to create the Binary file and burn it to a chip.  I'm basing this video on TI's excellent tutorial located here.
Steps:
  1. Setup CCS to output a binary file.
  2. Download and install Elprotronic's FET-Pro430 Lite software
  3. Open FET-Pro430 Lite
  4. Load the binary file created by CSS
  5. Define the MSP430 Group and the type of chip
  6. Press 'AUTO PROG.'
  7. Press 'RESET'
And you're done!
    Hi Dave,
          Thank you for your answer. I'm just curious how it would work without the launchpad, and how in the real industrial application would work in programming hundreds or thousands of chips at one time, for example. Sorry for my in-experience, just out of my curiosity.
    Thank you,
           Yuttanant
  • DaveYoung
    DaveYoung over 11 years ago in reply to e14 Contributor
    Hi Yuttanant-
    I don't know of any way to program an MSP430 as you describe. While there may be a way to buy a programmer and flash a chip, why would you? An MSP430 launchpad is far cheaper than any programmer on the market, and it works like a charm!
    Hi Dave,
       Thank you for such a great video. I would also like to know if I have to load the program directly to msp430 mcu without using the launchpad, do I need buy a programmer? How would I be able to do it? Please advise...
    Thank you,
        Yuttanant
    DAB over 12 years ago in reply to dr.akshay_1980@yahoo.com
    Akshay,
    Have you gone to the TI E2E website?
    They have a wealth of information on each of the different launch pads and peoples experience with the various flashing options.
  • DaveYoung
    DaveYoung over 12 years ago in reply to dr.akshay_1980@yahoo.com
    You could write the firmware to add this functionality, apart from anything related to the method of programming the part or changing the bootloader. Something along the lines of running a loop to test if the user has input the correct sequence, and if they have, then run another loop forever with the desired code. I bet someone has come up with a project that does this; I'd suggest looking around to see how others have solved this problem. Or if you're the first one, make a post on the community for the part that you want to use (Arduino, MSP430, pic, etc...) asking the best approach.
    Good luck!
