Code Exchange
Code Exchange
Blog How to Easily Burn a Binary File to an MSP430 Chip Using the LaunchPad
Join Code Exchange to participate - click to join for free!
  • Author Author: DaveYoung
  • Date Created: 15 Apr 2013 6:27 AM Date Created
  • Views 8359 views
  • Comments 15 comments
  • code_exchange
  • Code Exchange
  • programming
  • embedded
  • microcontroller
  • msp430
  • dyoung
DaveYoung
DaveYoung
15 Apr 2013
Often times someone other than the firmware designer on a development team needs to program a TI MSP430 chip.  An analog, apps, or test engineer, client; even an end user does not want to mess around with installing an entire IDE for a released firmware update.  There are too many settings and parameters to worry about, in addition to a heavyweight program which may require a paid license to be installed.
Thankfully, a Binary file can be created by Code Composer Studio.  A Binary file has everything a microcontroller needs to know in order to execute the program, and can be sent directly to the chip to be run.   Usign this file, a small computer program called Lite FET-Pro430 by Elprotronic can use the MSP430 Launchpad hardware to program a chip without the user having to face a single line of code. It's easy, free, and best of all, leaves little room for error.
The video below shows how to create the Binary file and burn it to a chip.  I'm basing this video on TI's excellent tutorial located here.
Steps:
  1. Setup CCS to output a binary file.
  2. Download and install Elprotronic's FET-Pro430 Lite software
  3. Open FET-Pro430 Lite
  4. Load the binary file created by CSS
  5. Define the MSP430 Group and the type of chip
  6. Press 'AUTO PROG.'
  7. Press 'RESET'
And you're done!
    Hi Dave,
          Thank you for your answer. I'm just curious how it would work without the launchpad, and how in the real industrial application would work in programming hundreds or thousands of chips at one time, for example. Sorry for my in-experience, just out of my curiosity.
    Thank you,
           Yuttanant
    Hi Dave,
    Thank you,
           Yuttanant
