Code Exchange
Code Exchange
Blog How to Easily Burn a Binary File to an MSP430 Chip Using the LaunchPad
Join Code Exchange to participate - click to join for free!
  • Author Author: DaveYoung
  • Date Created: 15 Apr 2013 6:27 AM Date Created
  • Views 8385 views
  • Comments 15 comments
  • code_exchange
  • Code Exchange
  • programming
  • embedded
  • microcontroller
  • msp430
  • dyoung
DaveYoung
DaveYoung
15 Apr 2013
Often times someone other than the firmware designer on a development team needs to program a TI MSP430 chip.  An analog, apps, or test engineer, client; even an end user does not want to mess around with installing an entire IDE for a released firmware update.  There are too many settings and parameters to worry about, in addition to a heavyweight program which may require a paid license to be installed.
Thankfully, a Binary file can be created by Code Composer Studio.  A Binary file has everything a microcontroller needs to know in order to execute the program, and can be sent directly to the chip to be run.   Usign this file, a small computer program called Lite FET-Pro430 by Elprotronic can use the MSP430 Launchpad hardware to program a chip without the user having to face a single line of code. It's easy, free, and best of all, leaves little room for error.
The video below shows how to create the Binary file and burn it to a chip.  I'm basing this video on TI's excellent tutorial located here.
Steps:
  1. Setup CCS to output a binary file.
  2. Download and install Elprotronic's FET-Pro430 Lite software
  3. Open FET-Pro430 Lite
  4. Load the binary file created by CSS
  5. Define the MSP430 Group and the type of chip
  6. Press 'AUTO PROG.'
  7. Press 'RESET'
And you're done!
  • gervasi
    gervasi over 13 years ago
    Getting CCS working isn't trivial if you're not used to it.  Lauchpads are almost free.  This is a nice alternative.
  • gervasi
