Code Exchange
Code Exchange
Blog How to Easily Burn a Binary File to an MSP430 Chip Using the LaunchPad
Join Code Exchange to participate - click to join for free!
  • Author Author: DaveYoung
  • Date Created: 15 Apr 2013 6:27 AM Date Created
  • Views 8371 views
  • Comments 15 comments
  • code_exchange
  • Code Exchange
  • programming
  • embedded
  • microcontroller
  • msp430
  • dyoung
DaveYoung
DaveYoung
15 Apr 2013
Often times someone other than the firmware designer on a development team needs to program a TI MSP430 chip.  An analog, apps, or test engineer, client; even an end user does not want to mess around with installing an entire IDE for a released firmware update.  There are too many settings and parameters to worry about, in addition to a heavyweight program which may require a paid license to be installed.
Thankfully, a Binary file can be created by Code Composer Studio.  A Binary file has everything a microcontroller needs to know in order to execute the program, and can be sent directly to the chip to be run.   Usign this file, a small computer program called Lite FET-Pro430 by Elprotronic can use the MSP430 Launchpad hardware to program a chip without the user having to face a single line of code. It's easy, free, and best of all, leaves little room for error.
The video below shows how to create the Binary file and burn it to a chip.  I'm basing this video on TI's excellent tutorial located here.
Steps:
  1. Setup CCS to output a binary file.
  2. Download and install Elprotronic's FET-Pro430 Lite software
  3. Open FET-Pro430 Lite
  4. Load the binary file created by CSS
  5. Define the MSP430 Group and the type of chip
  6. Press 'AUTO PROG.'
  7. Press 'RESET'
And you're done!
    DAB over 13 years ago
    Hi Dave,
    Good post.  This approach would be perfect if you need to program a lot of chips with the same program.
    I am assuming that you can just pop out the MSP430 chip and put another in its place to do the programming.
    Of course if you were going to do a lot of these chips, you could just put a ZIF socket on the Launchpad.
    Thanks
  • sanuzr
    sanuzr over 12 years ago in reply to DAB
    Hi DAB, For programming a lot of chips quickly, Texas has a Programmer named MSP-GANG, it can program upto 8 MSP430. Also no PC is required to program the chips (Once the Binary file is transferred to the programmer). Have a good day !
  • sanuzr
