Code Exchange
Code Exchange
Blog modern C++: initialise a static array inside a class
Join Code Exchange to participate - click to join for free!
  • Date Created: 24 Nov 2025 4:58 PM Date Created
  • Views 1843 views
  • Comments 10 comments
  • c++17
  • Modern C++
  • c++
24 Nov 2025
Pre C++17
In traditional C++, if you have a class that has a static array as data member, you have to initialise that array outside of the class.
class myclass {
protected:
    static uint myarray[4];
uint myclass::myarray[4];
You will typically have the declaration in your header file, and the definition (initialisation) in a cpp file.
Since C++17
With modern C++, you can do all in the above in the class declaration, with inline:
class myclass {
private:
    inline static uint myarray[4] = {};
The generated code is the same.
Thank you for reading.
    Jan Cumps 7 months ago in reply to vmate
    giving it a same name as a built-in type wasn't my brightest moment Slight smile
  • vmate
    vmate 7 months ago in reply to Jan Cumps
    Ah, sorry then, all the times I've encountered time_t, it has been just a typedef to a 32/64bit int.
    Jan Cumps 7 months ago in reply to Jan Cumps
    ... that sits in the nmea namespace:
    namespace nmea {
    using time_t = std::chrono::hh_mm_ss<std::chrono::duration<long long, std::ratio<1, 1000>>>;
    the time_t example doesn't apply here at all, since it's a fundamental type, so there is no ctor/dtor or any performance penalty.
    Not obvious from the snippet I posted, but it's a class (with a constructor) in this case:
    > Also, Return Value Optimization has been part of the spec (although optional) for like 30 years at this point if I recall correctly,
    > so C++17's guaranteed copy elision is not even needed for small and relatively simple types.
    Yes, it exists since c++11. Enforced by compiler (regardless of what command line switches are passed during build) since c++17.
