Code Exchange
Code Exchange
Blog modern C++: write my own function that returns true / false, and a value, part 2 (embedded friendly)
Join Code Exchange to participate - click to join for free!
  • Date Created: 4 Dec 2025 5:59 PM Date Created
  • Views 531 views
  • Comments 5 comments
  • gcc
  • Modern C++
  • c++26
  • c++
4 Dec 2025
what came before:
  •  modern C++: function returns true / false, and a value or error message
  •  modern C++: write my own function that returns true / false, and a value or error message - part 1 (embedded friendly)
C++ has released a new feature: return value parameter binding. It's a somewhat obscure name (some say: just like C++ itself Slight smile). Here is the short version of what it gives us:
A function (or member), traditionally, could return 1 "return value". Now, this value can be several things, captured in a class. And you can run a method of that return value while calling the function.
Example: you can have a parser function, that returns
  • the parsed values (several things)
  • and it can return a boolean success / failure at the same time. (so you can use if (myfunc() ... )
I've implemented this in a GPS message parser I wrote.
Original user code: the function returns a bool, and the data is returned via the i/o parameter o)
std::string reply = "$GPGLL,5051.83778,N,00422.55809,S,185427.150,V,N*4F";
nmea::gll o;
if (nmea::gll::from_data(reply, o)) { // data exchanged via an in/out parameter
  // do stuff
With return value parameter binding: the data is returned in parameter result. And the if makes a decision on that status.
if (auto [result] = nmea::gll::from_data(reply)) {
  // do stuff. result is the same object as o in the original code.
Spectacular? Maybe yes:
getting results as return values is neater than getting results via pointers or reference i/o parameters. And we don't have to choose between returning a status or a data set. We can do both.
In this example, the parsed value is available as the bound parameter result. And we call the result's function operator bool() (the if clause does).
This means that we can call the function and
  • decide what to do based on success/failure: the if statement
  • receive the results too, in our result "variable" (it's actually a bound parameter)
If you're interested in how this is coded, and how it's handled, leave a comment. The code is published on github.
    Jan Cumps 9 months ago in reply to Jan Cumps
    https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads
    GCC 15 is now released for ARM too.
    Jan Cumps 11 months ago
    code in action, for a Raspberry Pico GPS design:
    19 satellites in view from my back window. The parser mechanism described above is used. stl algorithms split the found satellites into glonass and gps types.
    DAB 11 months ago
    Nice post Jan.
    I like the idea of getting multiple types of information directly from functions.
    I flagged this as embedded friendly, but there is a caveat for ARM controllers:
    It needs C++ 15. If you are using a Raspberry Pico 2, in RISC-V mode, it will work. GCC15 is released for that.
    But as of today, there is no published ARM GCC 15 toolchain. If the OpenArm initiative sticks to its schedule, a version 15 release is imminent...
