Code Exchange
Code Exchange
Blog Need help coding
Join Code Exchange to participate - click to join for free!
  • Author Author: rmiltenberger
  • Date Created: 16 Mar 2018 11:24 PM Date Created
  • Views 3084 views
  • Comments 9 comments
Need help coding
rmiltenberger
rmiltenberger
16 Mar 2018
I have 4 sparkfun lummenati 3x3 bParts,
  I having a problem finding a code,
i have them daisy chained would like to make
a top hat band
any help would be greatly appreciated
thanks bob
  • rmiltenberger
    rmiltenberger over 8 years ago +3
    To Shabez, and Dave,, Wow, ok it took some doing, and slit of research. But I have my matrix, up and running. And it's gorgeous... 3x36 lights running... various colors across each successive board...…
    beacon_dave over 8 years ago in reply to rmiltenberger +2
    Here was my first attempt with APA102C LED's & the FastLED library Data on pin 6 Clock on pin 7 #include <FastLED.h> #define NUM_LEDS 1 #define DATA_PIN 6 #define CLOCK_PIN 7 CRGB leds[NUM_LEDS]; void…
    shabaz over 8 years ago in reply to rmiltenberger +2
    Hi Robert, If you can paste the entire output error, it will help, because it will likely mention which line the error was on. Also, precision is key, because you state the error is 'Leds does not name…
    They appear to be based on the APA102C pixel LEDs. As Shabaz has already told you in the other thread, you can use the FastLED library on the Arduino for this.
    FastLED LED animation library for Arduino (formerly FastSPI_LED)
    https://github.com/FastLED/FastLED/wiki
    Arduino Basics: NeoPixel Playground
  • rmiltenberger
    rmiltenberger over 8 years ago in reply to beacon_dave
    Hi Dave
    thanks, but as a total newbie,
    im not sure what I'm looking at,,
    i was given these boards and I'm lost in what I'm looking at,, I need more help than be directed to a library,,
    i appreciate your help a great deal but I'm still lost
    thanks
    bob
    Take a look at the code sample at:
    It's for Neopixels (WS2812B), so you will need to make a change for using APA102C
    After line 29:
    #define DATA_PIN 6
    you will need to add:
    #define CLOCK_PIN 7
    These pins 6 & 7 are the pins on the Arduino you have connected your LED data and clock lines to.
    Line 63 in the code:
    FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
    needs changing to:
    FastLED.addLeds<APA102, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
    After line 29:
    #define DATA_PIN 6
    #define CLOCK_PIN 7
    needs changing to:
