Code Exchange
Code Exchange
Blog sensible C++ coding convention - µOS naming standard
Join Code Exchange to participate - click to join for free!
  • Date Created: 1 Sep 2024 6:35 PM Date Created
  • Views 1871 views
  • Comments 7 comments
  • c++23
  • teseo_c++
1 Sep 2024
When writing reusable code, I like to be consistent and use standards. For C++, there are many flavours out there.
I've been looking around for guidance on writing modern C++ code, with templates. That's when I bumped into the µOS naming standards. µOS is a C++ RTOS, maintained by Liviu Ionescu. He 's been very active on this community for a long time, when this forum was used to support the Eclipse Embedded CDT plugin.
He managed to compile a reasonable naming convention set. Pragmatic, not pedantic.
A number of naming proposals try to cover all, or are detailed. I like a standard that handles the conceptual level. To my taste, the µOS standard has a good balance.
It's more brief than many other options out there, but I haven't found a miss. And I like how my code "sounds" when applying the principles.
When writing code, check it out. I've recently designed a C++ library, that (I hope) adheres to that standard. It helps me to stay consistent, and I hope it helps the user to understand my library's API.
that's all :)
Link to related posts.
    DAB over 2 years ago +1
    Thanks Jan. Naming conventions are always a good way to start a fight among software engineers. While most people don't care, they just want to get the code done, you always run into a few fanatics…
  • battlecoder
    battlecoder over 2 years ago +1
    Naming conventions are definitely a fighting ground for a lot of people. I personally think that any naming convention you want to follow is fine, as long as the code doesn't look like you put the ascii…
  • battlecoder
    Naming conventions are definitely a fighting ground for a lot of people. I personally think that any naming convention you want to follow is fine, as long as the code doesn't look like you put the ascii table in a blender and dumped it into your C file with some ice.
    However, there's some extremist views out there, and I've seen coding style suggestions that are meant to "improve readability" in theory, but in practice they have the opposite effect.
    Now, the convention you linked sounds reasonable for the most of it. I'd disagree with a couple of their suggestions, but that's just me. Naming conventions (just like "space vs tab", or "opening braces in their own line vs next to the block opening statement"), are down to personal preference. None of what they suggest is madness, it's all pretty reasonable and has a high degree of consistency (which is the important part of standards), and that already puts their conventions above a lot of others I've seen out there.
  • battlecoder
