Code Exchange
Code Exchange
Forum Python 3 code Question
Join Code Exchange to participate - click to join for free!
  • Replies 12 replies
  • Answers 3 answers
  • Subscribers 53 subscribers
  • Views 3334 views
  • Code Exchange
ellip
ellip over 9 years ago
Hi.  I am new to the Raspberry Pi.  I have a Raspberry Pi 3 and a PiFace 2.  I am trying to update a Christmas decoration made over 40 years ago by my father. It was run by a rotisserie motor and a wooden cylinder with copper strips and screws to make contact and light the stars up in sequences.
I have 5 stars in the following formation:
     1          2
          5
     4          3
I am trying to have the stars light up in a certain sequence with a small delay in between each function
1
2
3
4
5
1,2,3
2,3,4
3,4,1
4,1,2
1,2,5
2,3,5
3,4,5
4,5,1
1,2,3,4,5
then begin the sequence again.
I have tried following as many of the posts as I can and receive errors on everything from syntax to int and tuples.
I am sure that it is something that is simple to the rest of you but just eludes me.  Any help in any way will be greatly appreciated.
Elli
  • jdlui
    jdlui over 9 years ago +3 suggested
    Hi Ellen, Suggestion: With any problem I think it's helpful try and break things into pieces. Share more info with us on what you've tried, what isn't working, what code you are using. I.E. Have you tested…
  • mgillett
    mgillett over 8 years ago in reply to dougw +3
    I appreciated the two of you demonstrating two solutions to this problem. Further I appreciate seeing the first examples of going line by line through the code then the "better" coding style making the…
  • urkraft
    urkraft over 9 years ago in reply to urkraft +1 suggested
    To Douglas Wong: Sorry, i see now that your post was not directed to me. Was not very focused when i read it. I did notice that there was a very important bug in my code in that it did not handle interrupts…
  • clem57
    0 clem57 over 9 years ago
    Create an array with the options you wish like  http://www.thegeekstuff.com/2013/08/python-array/
  • ellip
    0 ellip over 9 years ago in reply to clem57
    Is there a way to "dumb" this down....I am a new "newbie" and haven't a lot of experience with Python....sorry if this is too ridiculous.
  • jdlui
    0 jdlui over 9 years ago
    Hi Ellen,
    I.E. Have you tested a basic python script to get PiFace to turn on a single light yet? Confirm that this is working before you proceed. Test it on a random light like an LED. Then test it on your ornament.
    Hardware - PiFace
    I've never worked with PiFace so I don't know what your hookup options are to your ornament. I assume you have already made your electrical connections? Completed to the point where you can turn on a light if you run some basic blink script? There seems to
    Code - The Loop
    What code have you tried so far? Share it and we can help you more easily.
    Here is an example code that will look through your lighting combinations. This will go through each lighting combination and wait 1 second in between. Try running it and see how it works. You can modify the wait time as well.
    Hope this helps!
    J
    import time
    # Example of a script to cycle through and change light sequence
    # Every lighting combination can be summarized as a '1' for an on light and an '0' for an off light.
    # Those combinations are shown below.
    lights = ['10000','01000','00100','00010','00001','11100','01110','10110','11010','11001','01101','00111','10011','11111']
    # Define wait time for our function
    waittime = 1 # Number of seconds between light sequences, measured in seconds.
    # We want this script to run perpetually so we create a while True loop
    while True:
      # We iterate through each item in our list of light combinations, which is called 'lights'
      for index,item in enumerate(lights):
      # Putting a bunch of text print outs so you can see how the loop iterates
      print('We are now printing combination number',index+1,'in our light sequence')
      print('Light combination is',item)
      # Here is where you would send the data to the PiFace to control its lighting.
      print('If we send these commands to a lighting system \nlight 1 is',item[0],'light 2 is',item[1],'light 3 is',item[2],'light 4 is',item[3],'light 5 is',item[4],'\n')
      # Insert some lighting command here. Use the on/off data stored in the item variable to turn your lights on or off.
      # Now we use time command to put a delay in between lighting instruction
      time.sleep(waittime)
      print('Completed all sequences. repeating')
  • ellip
    Ok...thank you for your reply
    i have the 5 stars (1-5) wired to the pi/piface.  They light up in sequence 5,4,3,2,1 then shut off in the same sequence 5,4,3,2,1,.
    This is the code i used
    from time import sleep
    import pifacedigitalio
    DELAY = 0.5  # seconds
    if __name__  ==  "__main__":
         pifacedigital = pifacedigitalio.PiFaceDigital()
         while True:
              pifacedigital.leds[5].toggle
              sleep(DELAY)
              pifacedigital.leds[4].toggle()
              sleep(DELAY)
              pifacedigital.leds[3].toggle()
              sleep(DELAY)
              pifacedigital.leds[2].toggle()
              sleep(DELAY)
              pifacedigital.leds[1].toggle
              sleep(DELAY)
    the lights will sequence until i stop them.
  • urkraft
    0 urkraft over 9 years ago in reply to ellip
    This code appears to give the specified results:
    #!/usr/bin/env python3
    import pifacedigitalio, time
    pfd = pifacedigitalio.PiFaceDigital()
    while True:
         pfd.output_port.value = 0x02
         time.sleep(0.5)
         pfd.output_port.value = 0x04
         time.sleep(0.5)
         pfd.output_port.value = 0x08
         time.sleep(0.5)
         pfd.output_port.value = 0x10
         time.sleep(0.5)
         pfd.output_port.value = 0x20
         time.sleep(0.5)
         pfd.output_port.value = 0x0E
         time.sleep(0.5)
         pfd.output_port.value = 0x1C
         time.sleep(0.5)
         pfd.output_port.value = 0x1A
         time.sleep(0.5)
         pfd.output_port.value = 0x16
         time.sleep(0.5)
         pfd.output_port.value = 0x26
         time.sleep(0.5)
         pfd.output_port.value = 0x2C
         time.sleep(0.5)
         pfd.output_port.value = 0x38
         time.sleep(0.5)
         pfd.output_port.value = 0x32
         time.sleep(0.5)
         pfd.output_port.value = 0x3E
         time.sleep(0.5)
    0 dougw over 9 years ago in reply to ellip
    It sounds like you have everything working, just a bit of code modification to get the right sequence.
    The main thing in your sequence is to toggle the devices you want on and then after a delay toggle the same devices off before toggling the next set on:
         while True:
              sleep(DELAY)
              sleep(DELAY)
                sleep(DELAY)
                sleep(DELAY)
              pifacedigital.leds[5].toggle()
                sleep(DELAY)
                sleep(DELAY)
                sleep(DELAY)
              pifacedigital.leds[1].toggle()
                sleep(DELAY)
              sleep(DELAY)
              sleep(DELAY)
              sleep(DELAY)
              sleep(DELAY)
              sleep(DELAY)
              sleep(DELAY)
  • urkraft
    To Douglas Wong:
    Strange, the code resulted in the exact sequence specified. If you had bothered to test the code that i published you would have seen that it did actually produce the specified sequence - and with much less code than the gobeltygoop you posted to "correct" me!
  • urkraft
    0 urkraft over 9 years ago in reply to urkraft
    To Douglas Wong:
    Sorry, i see now that your post was not directed to me. Was not very focused when i read it. I did notice that there was a very important bug in my code in that it did not handle interrupts and could easily enter an undesirable state when stopped. A better solution to my submission follows:
    import pifacedigitalio, time, sys
    try:
         while True:
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
              time.sleep(0.5)
    except:
         pfd.output_port.all_off()
         pfd.deinit_board()
         print('\nExiting due to unexpected interrupt.')
         sys.exit(0)
  • urkraft
    Since there is a lot of unnecessary repetition and generally bad programming practices in my previous posts on this topic, i have cleaned up my code a bit. This is my alternative solution:
    pause_time = 0.5
    the_sequence = [0x02, 0x04, 0x08, 0x10, 0x20, 0x0E, 0x1C, 0x1A, 0x16, 0x26, 0x2C, 0x38, 0x32, 0x3E]
    try:
         while True:
              for seq in the_sequence:
                   pfd.output_port.value = seq
                   time.sleep(pause_time)
    except:
         pfd.deinit_board()
         sys.exit(0)
    0 dougw over 9 years ago in reply to urkraft
    sorry - I didn't see your code before posting. My code was not trying to be efficient, just an easy extrapolation of the working code.
