Code Exchange
Code Exchange
Forum GitHub: automate project documentation with DoxyGen, and publish online after pushing commits
Join Code Exchange to participate - click to join for free!
  • Locked Locked
  • Replies 13 replies
  • Subscribers 47 subscribers
  • Views 4070 views
  • doxygen
  • yaml
  • github.io
  • github
  • teseo_c++
Jan Cumps
Jan Cumps over 2 years ago
Moved to  GitHub: automate project documentation with DoxyGen, and publish online after pushing commits
The title says it all. You can generate project documentation from the comments in the source files. I'm using doxygen for that. What I tried today (and succeeded in), is to make a GitHub action that:
  • kicks off a process on one of its job servers that automatically generates the documentation
  • kicks of a second process to deploy that on github.io
Prerequisite at this point, is that you know how to configure your project for doxygen. And that you know how to write good comments that make for good documentation. Here's a link to one of my ./Doxygen configuration files, if you need inspiration. Take care that you have such a file checked into your project's github repository.
Then create a new GitHub action. You can that by creating a .yaml file in the .github/workflow subdir of your project and push that, or you can open your GitHub repo online, and navigate to Actions -> wew workflow -> set up a workflow yourself. The latter option has the advantage that you get some code support and validation. I named my file .github/workflows/doxygen-gh-pages.yml.
I set up 3 actions, that all will run on GitHub hosted servers:
  1. checkout the code
  2. generate the documentation with a nice GitHub market place plugin.
  3. publish to github.io
Here's the full content
# Sample workflow for building and deploying a Doxygen site to GitHub Pages
name: Deploy Doxygen with GitHub Pages dependencies preinstalled
on:
  # Runs on pushes targeting the default branch
  push:
    branches: ["main"]
  # Allows you to run this workflow manually from the Actions tab
  workflow_dispatch:
# Sets permissions of the GITHUB_TOKEN to allow deployment to GitHub Pages
permissions:
  contents: read
  pages: write
  id-token: write
# Allow only one concurrent deployment, skipping runs queued between the run in-progress and latest queued.
# However, do NOT cancel in-progress runs as we want to allow these production deployments to complete.
concurrency:
  group: "pages"
  cancel-in-progress: false
jobs:
  # Build job
  build:
    runs-on: ubuntu-latest
    steps:
      - name: Checkout
        uses: actions/checkout@v4
      - name: Setup Pages
        uses: actions/configure-pages@v5
      - name: Run Doxygen
        uses: mattnotmitt/doxygen-action@v1.9.5
        with:
          # working-directory: '${{github.workspace}}/Kerbal/doxygen'
          doxyfile-path: 'Doxyfile'
      - name: Upload artifact
        uses: actions/upload-pages-artifact@v3
        with:
          path: doc_generated/html
  # Deployment job
  deploy:
    environment:
      url: ${{ steps.deployment.outputs.page_url }}
    needs: build
    steps:
      - name: Deploy to GitHub Pages
        uses: actions/deploy-pages@v4
The nice thing is that you don't have to store any credentials. They are dynamically generated by GitHub. As repository manager, you control what can be in that .yaml file. And you can thus control what is allowed, and what actions run.
Here is a part of the run logs:
Checkout and doxygen html documents generation
Then deploy to github.io:
I created this for my Pico GPS library. The documentation is online: https://jancumps.github.io/pico_gps_teseo_i2c/
Link to all posts.
  • Fred27
    Fred27 over 2 years ago +2
    My favourite use of a build pipeline was when I was the solo developer on a large project. Nobody told me I couldn't go the whole hog and use not just the CI part but the CD (Continuous Deployment) too…
    shabaz over 2 years ago +1
    That's very helpful! Relevant to all projects. GitHub Actions is powerful, looking forward to using that more. And, it's impressive that all that capability is for free with GitHub, including the web…
    Jan Cumps over 2 years ago +1
    VSCode Github Actions extension shows run statuses, and allows triggering a runfrom the IDE
    Jan Cumps over 2 years ago in reply to cstanton
    Ow, when I tried to create this in the software group, there was no option to create a blog
  • cstanton
    cstanton over 2 years ago in reply to Jan Cumps
    I would say as this pertains to github, used for code, it'd be better in  Code Exchange
     cstanton , can you delete this forum post? It's now  GitHub: automate project documentation with DoxyGen, and publish online after pushing commits
